01-27-2007, 10:03 AM | #1 |
Simple bolt-on 4bbl carb Opinions Needed
I'm a new member looking for opinions on inexpensive carb replacement for daily driver 327ci engine in a 71 C-10. Something that needs almost no adjustment out of the box and has a good reliability. Any suggestions are appreciated.
01-27-2007, 10:10 AM | #2 |
Re: Simple bolt-on 4bbl carb Opinions Needed
I find Edelbrock to have the best OUT OF THE BOX carbs. You must remove the idle screws hoxever and blow a little air through the passages. For some reason the seem to have filings in them all the time. My favorite is still the Quadrajet but to get a good rebuilt one seems few and far between.
01-27-2007, 10:15 AM | #3 |
NAPA sells a replacement Q-jet I think... any spreadbore carb will work (600-650cfm) but will need a little tuning. is it an auto or manual? is it manual choke or electric (or divorced?) 2bbl or 4 bbl? all these will matter when you go for your replacement. Anything but Q-jet is going to require a new fuel line from pump (if you have original metal line now)...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 01-27-2007 at 10:15 AM. |
01-27-2007, 10:32 AM | #4 |
Set up will be auto 350 trans, 4bbl stock manifold, electrdizzy, and ??? choke. Thanks.
01-27-2007, 10:36 AM | #5 |
maybe post a notice that you need to have a qjet rebuilt by a member in your area ( if you cannot do it yourself ) and it would be the best way. Lots of capable members in my opinion
01-27-2007, 10:40 AM | #6 |
takes close pics of all sides of your surrent setup (without air cleaner) and the board can tell you what you have and a better recommendation. If it's stock intake then you are looking for "spreadbore" carbs (not many Holley's made like that) but the Edelbrocks are. Lots of guys like the 1406 and it can adapt to a lot of installs. You can also upgrade to electric shoke but some like manual (with cable) divorced choke is manual by way of a coil spring on top of the intake....
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
01-27-2007, 10:55 AM | #7 |
Are you trying to get more power or is there a problem with the current one? What's on there now?
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
01-27-2007, 11:23 AM | #8 |
01-27-2007, 11:28 AM | #9 |
The new carb will replace holley economy carb which the owner said was not working when i bought the engine (1968 327ci) I have heard that the Edelbrock is a good bolt-up and go carb. SPREAD bore and SQUARE bore?? What is the difference?? I need it to bolt to stock '68 intake. Also, does the fact that I will run elec distributor mean I can do electric choke? Thank you.
01-27-2007, 11:47 AM | #10 | |
I'd say rebuild what you have - even sending it off to Holley or an online rebuilder. |
01-27-2007, 03:01 PM | #11 |
68 C10 Longbed
I say go with an edelbrock 1406 with electric choke. Throw it in on and your done. Pretty much set your idle and your done. I would adjust the idle screws for highest vacuum also but that is it. They are out of the box dependable. Good luck.
01-27-2007, 03:49 PM | #12 |
i just bought "yesterday infact" a 625 road demon. i have yet to install it but i decided on it because everything i've read on demon has been positive. holly on the other hand got tons of bad reveiws. why, i don't know but alot of it had to do with having to tune it ALL the time.
ondrew |
01-27-2007, 04:17 PM | #13 |
keep us updated on the road demon. I have heard alot of problems with them hope yours is good.
01-27-2007, 09:09 PM | #14 |
Carter AFB, if you can find one...
