01-27-2007, 11:22 AM | #1 |
Factory tach with new HEI questions!
Ok this should be real simple but I am hoping I just am missing somthing. I just put a stock cluster out of a c50 or better into my 70 Low buck truck build and I also put in a new HEI. I have 12volts acc power to the B+ wire on the tach and the other end is conected to the tach lead of the HEI. I fired it up and nothing Is their a test other then what I did to see if the tach works? I would really like to keep the stock one if I can but!!!
Kevin LFD Inc. |
01-27-2007, 11:39 AM | #2 |
Roadtrip!
Re: Factory tach with new HEI questions!
Do you have the cluster grounded?
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
01-27-2007, 11:48 AM | #3 |
I do not have any extra ground wires than what comes on the cluster. Or do you mean the tach cluster it self?
**Ok now I just went out and fired it up and the tach kind of is working but it shows that my motor idlles at 500 and it will not rev past 7-800? Any ideas on this one. It was late last night when I fired it up so I shut it off quick and did not notice thy movement but now I do just not enough.** Kevin LFD Inc. Last edited by Rokcrln; 01-27-2007 at 12:00 PM. |
01-27-2007, 11:51 AM | #4 | |||
Union Electrician
DEAD TACH!!! The ground could matter, but I do not have mine grounded and don't have any of the dashes I restored grounded when testing tachs and have never had any issues.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
01-27-2007, 11:51 AM | #5 | |||
Union Electrician
Some the dashes had a small jumper form the rear tin to the cab for ground
01-27-2007, 01:18 PM | #6 |
A shot in the dark,But maybe it's a 6 cyl tach?
69 Lwb C-10 402/700R4 70 Lwb C-10 250/3pd Wisc. |
01-27-2007, 11:33 PM | #7 |
To me it sounds like the needle may be sticking or rubbing the tach face, stopping it at 7-800. Did you happen to check to see if the needle would bounce back and forth before you installed it?
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
01-28-2007, 12:32 AM | #8 |
its all about the +6 inches
i've seen a few bum tachs di this.
01-28-2007, 01:20 AM | #9 |
No I did not check it before but I will pull it out before I finish putting it all back together!
Kevin LFD Inc. |
