Old 01-27-2007, 05:07 PM   #1
67c-10Texas
Rear Trackbar Help
I am installing the CPP Deluxe Trac Bar and the instructions are not the best.
Part number 6572DT-BK
Am i suspose to remove the factory Trac Bar mount on the right frame rail.
i have everything installed and the bar seems to long. do i need to force the trailing arm over to accept the trac bar?
thanks
67c-10Texas is offline   Reply With Quote
Old 01-27-2007, 06:46 PM   #2
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: Rear Trackbar Help
thanks
the track bar mount should be on the left(drivers side) frame rail.
how far off is it? can you adjust the bar to fit into it? and have you measured to see if your axle is sitting in the middle of your truck? you should be able to measure from your tire to your framerail on each side to see if it's centered or not.
IvelDesigns is offline   Reply With Quote
Old 01-27-2007, 07:47 PM   #3
kelsfine69
18 Till I Die
kelsfine69's Avatar
When I took off my factory track bar for chroming it did not line up when i put it back on. had a buddy push on the box, slid right it.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 01-27-2007, 08:00 PM   #4
chevykevy
chevykevy's Avatar
I was dealing with a similiar problem today. I am doing a frame up on a short 68 and when I measure from the wheel to the frame I am 1/2 to 3/4 wider on the left side? Will weight on the truck make a difference? The trailing arm lines up without persuasion?
chevykevy is offline   Reply With Quote
Old 01-27-2007, 08:04 PM   #5
IvelDesigns
having weight on the rear end make a big difference when installing your panhard bar. the lower you frame is to your rear end, the "longer" the bar becomes.
you should be fine sliding the rear end over to get it into the mount, but don't waste time adjusting it until you have the bed on the frame and the wheels on the ground, and have the truck at ride height.
Old 01-27-2007, 08:12 PM   #6
chevykevy
chevykevy's Avatar
What is the best way to measure to see if the rear is centered? I heal a level on the tire and measures to the frame? I came up with the 1/2 to 3/4 inch difference. Will I need to get an adjustable panhard bar or do you think everything will fall into place 233.0....once t.he bed is on?
Old 01-27-2007, 10:13 PM   #7
67c-10Texas
the bed is not on. the axle perches are not welded either. should i leave the track bar off until i get the perchs welded? it is off about an inch and can't adjust the play with the jam nut. there is not any weight on the axle and it is hanging free. 5" rear springs
Old 01-28-2007, 12:19 AM   #8
IvelDesigns
is the bar and inch short, or inch to long?
Old 01-28-2007, 01:00 AM   #9
67c-10Texas
it is too long
Old 01-28-2007, 01:08 AM   #10
IvelDesigns
i'm no pro, but i would say get your perches welded in, then worry about the track bar. it's a bit concerning that with no weight on the rear end, you're already an inch past the mount. (i'm assuming you have it adjusted all the way in) but, my guess is that once you get the perches in, and hook things up, you will need to adjust your panhard out some to get the rear end centered.
Old 01-28-2007, 12:29 PM   #11
67c-10Texas
thanks - i will try that
Old 01-28-2007, 01:10 PM   #12
centsless
sufficiently talented fool
centsless's Avatar
the bed is not on......there is not any weight on the axle and it is hanging free. 5" rear springs
Don't forget, the center measurements and adjustment should be done AFTER the bed is installed and the truck is sitting on level ground. Once the bed is on, the bar may need to be about an inch longer than it is without the weight of the bed on the truck.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
