Old 01-27-2007, 07:05 PM   #1
sevt_chevelle
Lost amongst the CORN
sevt_chevelle's Avatar
Door hinge rebuild services
Anyone know of door hinge rebuilders? looking to get my 49 hinges done.
I did happen to find these on a google search.
http://www.bowtiebits.com/Catalog/do...et_1214731.htm
Currently working on How To Videos and custom metal
70 Chevelle gettin Sliced and Diced Anything But STOCK
70 Chevelle SS455 not a typo its a BUICK BABY
49 and 72 Chevy Trucks restored to original...close to it
Drommer Stor....Norwegian for Dream Big
http://s969.photobucket.com/albums/a...lle/?start=all
https://www.flickr.com/photos/47922830@N03/
Pictures of my work and projects
sevt_chevelle is offline   Reply With Quote
Old 01-27-2007, 07:23 PM   #2
pgf545
pgf545's Avatar
Re: Door hinge rebuild services
I just got a set of pins and springs for my dad's truck. I haven't tried to rebuild them just but I will let you know when I do. Doesn't look that hard.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 01-28-2007, 11:31 PM   #3
solidaxel
solidaxel's Avatar
Bernie,
Tell me how hard it is, and how much time you spend on four of them.
I had a guy do my four and I supplied him with the springs and pins and he broke 2 springs so I got 2 more and he charged me $100.00
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-29-2007, 12:01 AM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
Jeff at Bowtie Bits does a top-notch job with anything he rebuilds. I wouldn't hesitate to buy rebuilds from him.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 01-29-2007, 10:49 PM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
They are actually easy to redo providing you have the parts and good cores. I drive or drill out the pin, media blast the parts and push in the 2 bushings from the pin kit. if you don't have a the spring and lever on the hinge you just tap in the pin and peen the other end.
The hinge with the spring and spring lever is a trickier. you may have to remove the hinge stop pin and lever, repair or replace the lever and redo the pin and peen it. then connect the spring and push in the bushings and the tap in the hinge pin.
The key is good cores, a sand blaster, ability to fabricate the lever arm and some patience.
$100 to rebuild 4 is probably not a bad deal as long as they turned out right.
dwcsr is offline   Reply With Quote
Old 01-29-2007, 11:00 PM   #6
Hart_Rod
Hart_Rod's Avatar
Was going to tell you to buy a new set from Goodmark, until I looked at the prices! $400 for a complete set.
http://goodmarkindustries.com/GMCKTruck4755.html
Hart_Rod is offline   Reply With Quote
Old 01-30-2007, 10:08 AM   #7
solidaxel
solidaxel's Avatar
[QUOTE=dwcsr;
dwcsr,
why would you put brass next to these two steel parts, those pins are so hard you can make punches out of them!
The pins will never ware out, and having the brass in there you are asking for a rebuild after a short use period. There is a lube point on the hinge that will last for another 25 years, and that is all I am looking for !!!!
LS 3 4L70E
Old 01-30-2007, 07:22 PM   #8
dwcsr
Hollister Road Co.
dwcsr's Avatar
Unfortuneatle they do wear out hence the thread, but the hinges on my truck have teflon bushings as do most all the 552nd- 59. The kits have the brass, not sure on the 55 down. the very reason bushing are used is because to pieces of the same metal rub on each other and most owners never lube them properly. A brass bushing has alway been used as a sacrifice part in what evert applications its used in so that the main pieces don't get worn out usually only the brass or bronze wears out. they also tend to hold lubrication better due to the porus nature of brass and bronze.
Old 01-30-2007, 11:00 PM   #9
pgf545
pgf545's Avatar
We got a kit from Brothers and they come with a bronze type bushing. The original hinges were metal to metal with no bushings. The kit is a universal one so there will have to be some modification done. I need to take some measurements but it looks like the hinges will have to be drilled out to acceot the bushings and then the pins will have to be shortened for the early hinges. If I remember right from my auto parts days the bushings are self lubricating bronze. The bronze is a little tougher than the brass but will still wear. The good part is that they will now be replaceable when they wear out. Most later model cars and trucks use this same bushing. I know they look exactly like the bushings in my Camaro. It is going to be a while before I get them rebuilt but I will take lots of pictures and give my view of the assembly.
Bernie
