Old 08-26-2002, 08:40 AM   #1
Andy4639
Old member
Andy4639's Avatar
Cool Brakes
Does anyone know if swapping a power brake booster and master cylinder into my 88 4wd from a 96-99 4wd will improve braking/pedal feel? What needs to be swapped to make this work right.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-26-2002, 01:05 PM   #2
ThreeQuarter
ThreeQuarter's Avatar
What exactly are you looking for? (What is "improved"?) Are the brakes too hard or too soft? Or is it the 1/2 mile of pedal travel before you actually start braking that is bothering you? Unfortunatley GM has designed them that way, but some trucks are not as bad as others.
If they're all the same part numbers then it probably won't. Might call a parts store and ask for price on a booster and M/C for an '88, then ask if that's the same part number for '96-ish. If they're not then you might see good results. Of course they might not be compatible, too. I don't know if 4-wheel ABS that was available on later models would affect this.
Also, I know the ext. cabs got bigger brakes (at least in the earlier years) so that might matter if you're swapping from reg. cab into an ext. cab.
I wanna hear how this turns out.
Ben
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'94 Ford Explorer XLT 4wd
'25 RAM 1500 Laramie 4wd
ThreeQuarter is offline   Reply With Quote
