Old 01-27-2007, 11:27 PM   #1
[ol'Blue]
[ol'Blue]'s Avatar
Smile I just drew a cantilever setup on AUTOCAD
Do ya'll like it?
the top one is fully inflated bag.
the bottom is deflated.
im open to suggestions, on how to improve this.
thanks.
[ol'Blue] is offline   Reply With Quote
Old 01-27-2007, 11:47 PM   #2
poorboy
poorboy's Avatar
Re: I just drew a cantilever setup on AUTOCAD
Looks cool. It looks like it might have a problem raising back up. With the bar straght like that it looks like it might just push and bind. I think when lowered the bar needs to be like the upper pic and when it's raised it should look like the lower pic. I might be wrong someone will coorect me for sure if I am.
poorboy is offline   Reply With Quote
Old 01-27-2007, 11:57 PM   #3
[ol'Blue]
[ol'Blue]'s Avatar
thanks, for the input, but i dont know either!
anyone have anymore ideas??
Old 01-28-2007, 04:33 AM   #4
SlammedDime
SlammedDime's Avatar
It will work without binding, but I'd recommend that you bring your pivot point on the rocker arm up, and back towards the bag a little bit. Might also want to consider moving the tabs that the linkage connects to on the axle higher up on the axle tubing, rather than 90° off the side. Reason being is that there is a lot of force there, and if your welds are sub-par, or you don't have much experience welding, you will experience some problems there, maybe not right away, but down the road. If you can weld, and I mean weld, then by all means, the only thing I'd change is what I first mentioned.
Keep in mind however that you will need some way to locate the bag, unless you are going to use a shockwave. Otherwise you will end up with the bag bowing out in some direction which will cause things to break pretty easily. See pictures of my cantilever setup at http://gallery.mattzuba.com/v/Truck
here's one picture for example...
Matt
Admin @ AirRideTalk.com
Win FREE Viair compressors!
SlammedDime is offline   Reply With Quote
Old 01-28-2007, 06:48 PM   #5
[ol'Blue]
[ol'Blue]'s Avatar
thanks, how do you mount your shocks?
