Old 01-28-2007, 12:48 AM   #1
RicksTrucks
RicksTrucks's Avatar
T5 in one of our trucks?
A friend of mine purchased a 350 engine that came with a T5 tranny. Anyone put this setup in before? Do you know what length shaft to use? He has heard that you would you an A/T crossmember - anyone can comfirm? Also, he can't figure out something about the clutch piece that on a regular 3 speed sets in a slot on the frame and bolts to the engine - how would you do it with this setup?
Any input would be appreciated. Thanks.
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 01-28-2007, 01:10 AM   #2
Brad
Out of the carpool lane.
Brad's Avatar
Re: T5 in one of our trucks?
I've got the Camaro T-5 hooked up to my I6 and didn't use a rear mount although I plan on putting one on down the road. Even if you can somewhat use the AT crossmember, it'll still require mods to bolt it to the T-5. I'm just going to make a crossmember out of tube steel and build up the mount on that. I'm not sure what you mean by the 3 speed question.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 01-28-2007, 01:33 AM   #3
RicksTrucks
He is swapping out the 6 for an 8. And on his current 6 with a 3 speed, something on the tranny pivots off of a spot on the frame. And apparently part of that setup bolts to the engine, but he doesn't know where that same part on the T5 would bold to the V8.
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
72 LWB C-10
72 Blazer 4x4 4spd
Old 01-28-2007, 01:41 AM   #4
Brad
Brad's Avatar
I think he's referring to the clutch linkage. My understanding is that they're totally different between the V8 and the I6. Regardless, they both bolt up to the engine and attach to the clutch fork. Nothing attaches to the T-5 itself except of course the driveshaft. The T-5 simply bolts on to the bellhousing using 4 bolt holes that need to be drilled out to 1/2".
Old 01-28-2007, 02:20 AM   #5
lilpup69chevy
67-72 parts finder
lilpup69chevy's Avatar
a T5 would not hold up with a v8 for very long, well for just driving along maybe it would but if he intends on performance a T5 is not something i would use, i have broke many t5's in my mustang gt, now if it is a stock engine and he isn't gonna drive it hard it might be ok, personally i'd rather run a muncie four speed or a new venture 5 speed trans, or if its in the budget a t56, but with a V8 before i'd run a t5 i'd go with an automatic thats just my 2 cents
1969 chevy shortstep 2wd (under construction)
1981 chevy scottsdale lwb 2wd (parts chaser)
2004 pontiac gto (daily driver)
2004 pontiac grand prix gt (the ol ladys car)
1985 chevy short wide
1970 chevy c10 lwb (another parts rig)
1969 gmc lwb (rainy day project)
1968 chevy lwb c10 250 I6 3 spd (soon to be swb)
lilpup69chevy is offline   Reply With Quote
