Old 01-28-2007, 04:16 AM   #1
69 air cab
the old 6 to 5 lug conversion question
I have a 69 c10..........to change to the 5 lug can I just put a 72 rearend under my truck? If so what else has to change? Are they the same width?
thanks
69 air cab is offline   Reply With Quote
Old 01-28-2007, 07:00 AM   #2
Aarons72s
Re: the old 6 to 5 lug conversion question
It is wider by 1 1/2" but will still bolt right in. Or you can keep your existing axle housing and get 71-81 truck axles out of a junk yard 12 bolt and grab a set of 11-5/32" by 2-3/4" brake drums for or off of a 74-87 truck. And just leave your stock brakes intact. Hope this helps.
Aarons72s is offline   Reply With Quote
Old 01-28-2007, 09:00 AM   #3
70GMCer
70GMCer's Avatar
But wouldn't the axle bearings on the longer axles be 3/4" off the axle races on each side?? I thought I read that on here some time ago....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-28-2007, 09:14 AM   #4
Aarons72s
Its close. I did that type install on a 67 axle I have under my orange and white right now.There is about 1/4" ton 1/8" still left with this install, well at least on mine. Jim PA has already done this and has been driving his.
http://67-72chevytrucks.com/vboard/s...d.php?t=215095
Old 01-28-2007, 09:25 AM   #5
70GMCer
70GMCer's Avatar
that's good info to know Aaron......
1997 GMC Sierra Ext
1965 Mustang
