Old 08-26-2002, 10:54 AM   #1
Nichboy
Radiator Flush
What is the proper way to flush my radiator. I remember when i was a kid putting a garden hose in one of the heater hoses and running water through it, don't know if this was right or which hose i used. Need help here guys. Thanks
1971 Chevy SWB
Oklahoma City, Oklahoma
Nichboy is offline   Reply With Quote
Old 08-26-2002, 11:27 AM   #2
Southpa
Southpa's Avatar
Drain the system, chop through one of your heater hoses and install a T-connection. Forget which hose, they are different sizes so you better get the T first and figure it out. They (T connection) are just a cheap little plastic unit. Take the lower rad hose off the rad and hook a garden hose up to the T connection. Turn on the water and watch the gunk pour out.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 08-26-2002, 12:08 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Don't they sell radiator flush kits? I think they have a piece that connects to your hose but I don't know how it hooks into the system.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 08-26-2002, 02:16 PM   #4
COBALT
COBALT's Avatar
Yes they do. The kit recomends you put the spout in the main radiator kneck, and connect the garden hose to the "T" (the lower heater hose), start the water, start the truck, and let fluid fly out the top spout until it turns clear. I stuck a plastic hose onto the spout and drained the junk into a 5 gallon bucket.
I wouldn't screw around trying to disconnect the lower hose.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 08-26-2002, 05:21 PM   #5
1967LWBstepside
'Heavy Metal' Redefined.
1967LWBstepside's Avatar
I used to have a Prestone kit on mine. Worked well but the plastic T aged and eventually broke so if you install it, check it periodically so you won't get stranded anywhere after years of heat break it down.
It installed into the smaller of the two heater hoses if I remember correctly.
1967 C10 LWB stepside, 250 engine, GM HEI, aftermarket A/C., Clifford Performance intake, Stovebolt split headers, Carter AFB 500, X-pipe & Dynomax Super Turbos, 1 piece custom driveshaft, cyprus bed wood & stainless bed strips.
Starkville, Mississippi | My Truck Page
1967LWBstepside is offline   Reply With Quote
Old 08-26-2002, 05:29 PM   #6
Project1970
14.1 @ 96MPH
Project1970's Avatar
I've had the Prestone kit on my truck for as long as I can remember and have yet to have any problems with it. I first started working on my truck 3 or 4 years ago and it was on there then; my guess is my dad installed it about 12 years ago or so. Of course, your mileage may vary.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 08-27-2002, 07:36 AM   #7
Ed ke6bnl
What I did is to get a piece of water pipe tha t fit the lower hose and cut it about 5 in. and sealed one end off with a fitting for a garden hose. I drill a hole in the side at an angle drilled toward the open end and welded in a 1/2 in tube with a connector for my air compressor. Remove top hose connect tool to bottom hose and let fill with water and when it is running out let go with the air hose fitting and the crud will fly out. I have done this dozen of times on my old econoline pu that had sat for 14 years and developed rust in the block I have flushed bothe the block and the radiator. Stat needs removal for the block flush. I just made a tool the the radiator shop used the first time on my truck that cost me $30 dollars to get done. I could not have afford the consecutive clean out that were necessary to get the engine and rad clean. Not an issue any longer all is cleaned out. Ed ke6bnl Agua Dulce.
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
