wheels
what are a good looking five spoke rim that I can get for a six bolt pattern?
In Memoriam...
Re: wheels
Board member PKJ put some modified '07 Tahoe 20's on his and I think they look killer...Maybe he can fill in some details on the mods req'd...
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." |
My truck is in pieces!
Re: wheels
Those look awesome! Did he have to modify the center hub?
The LuvShack Garage
Re: wheels
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
its all about the +6 inches
Re: wheels
when you look for 6 lug rims, look in the 4X4 section of the catalogs. If you put 85 K/5 in as a search, you'll get wheels that'll clear disk brakes, and have the right size hole for the hub.
#6 | |
Texas Big Wig
Re: wheels
I saw these on a truck drive'n down the road one day, I thought they looked good (the truck was a 67-72 & the wheels are Silverado SS wheels) I just did a google img. search for these pics ![]() ![]() ![]() |
Re: wheels
as you can see in the pic, i have those mounted to the original drum brakes.
the fronts use a 6 lug to 6 lug 1 1/4 inch adapter. the adapter is needed mostly to get the con-cave center cap to clear hub. i feel that the 1 1/4 adapter is a little to much. i will not be able to lower much more with that tall tire on it. when i switch to disk brakes no adapter will be needed. the rear uses a 2 inch adapter, that gives a perfect backspace. note 68 rearends are narrow by 1 inch on each side. |
#8 | |
Re: wheels
Re: wheels
i believe its the 67 and 68 only that have the narrow rear. maybe someone can chime in on this.
Re: wheels
67 - early 70 rears are narrower by 3/8 inch on each side.
Re: wheels
Re: wheels
thanks longhorn. i have heard so many differant measurements. yours sound most reasonable.
#13 |
Re: wheels
57 1/2 inches verses 56 inches.
It's actually 3/4 inch per side. My mistake. Glad I pulled out my notes to confirm it. |
