I am looking at some 22x10 wheels with 6.5" backspacing to put on the 71 c10. I am putting the truck on bags and will be laying frame.
![]() Thanks for the help!
71 Chevy Long Bed (gettin' bagged) 84 GMC K1500 (Sold) 85 Monte Carlo SS white w/gray int. (being a dumba** and totaled it ![]() 85 Monte Carlo SS clone T-top (Sold) 72 Chevelle-tubbed 64 Buick Sportwagon |
Active Member
![]() Join Date: Oct 2006
Re: 22" wheels... Will they fit??
I am running 9.5 with 5.5" backspacing 20's on mine and I have no rubbing issues as far as side to side but mine is only bagged. You should be fine as far as height.
I don't think I have ever heard of anybody running 10" wide tires on the front. You better do your homework.
Active Member
I belive there is a member here that is running 10" rims on the front I don't remember his name but when I find him I will let you know. The only problem you will have is the backspacing you will probably hit the a-arm. Lock to lock I have about an inch to spare. I have at least 2 to 3 inches of space at a full turn from the fender. So IMHO go with less backspacing.
why would you want a 10 in front anyway. Most wheel manufacturers that make these stock wheels (non-custom orders) make two widths. Usually they will have a 9.5" or 10" AND a 8" or 8.5".
I am looking at some used wheels, and all 4 are 10" wide. +20mm offset 6.5" backspace
Outlandish Trends - FL
That's an awful wide tire to be turning up front. If you want to lay frame, I hope you got some good fab skills. You're going to have to start cutting.....a lot.
-Bret 67 short-fleet sold! |
im running 10 inch wide 22 on a 90 suburban but i dont know the backspacing. im bagged and everything clears. running a 305 40 22 tire
