01-28-2007, 09:26 PM | #1 |
Junior Member
K20 Frame Rails & Dana Axels in PA
These are from a 1970 GMC . The frame rails have some heavy suface rust,but no holes.Thought maybe somebody can use them to repair or modify there frame?100.00 OBO The front axel is a dana 44 with drum brakes.100.00 OBO.The back axel is a dana60 150.00 OBO. I haven't opened them up to check out the ratios,but they are probably 4.10s.I also have the cross members available.If you want it all or just a part lets work out a deal.
01-29-2007, 07:09 AM | #2 |
Re: K20 Frame Rails & Dana Axels in PA
I'm interested in the Danas, are they 6 lug or 8 lug? If you give me the numbers to the right top of pumpkin I'll look them up. Are they flat top knuckles? J.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
01-29-2007, 08:20 PM | #3 |
Junior Member
Jaros44 They are 8 lug & they do have flat top knuckles,I probably won't have a chance to check on that number till next weekend.717-271-3032 If you want to come check them out.Thanks
01-30-2007, 07:08 AM | #4 |
I'll probably be able to get over there this weekend. J.
02-12-2007, 09:25 PM | #5 |
Junior Member
Anybody,These really need to go.
02-12-2007, 10:01 PM | #6 |
do you have the crossmember that goes under the T-case? and the one just behind the cab?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
02-13-2007, 08:51 AM | #7 |
also the rear cab mounts... I just Pm'd you brother and will give him a call today.
02-13-2007, 09:19 AM | #8 |
do you still have the axles? if you do ill tell one of my friends who is looking for some 8 lug axles for his k5.
1985 1500 454, 4l80e, 12 bolt, 5/6 drop, 20s |
02-13-2007, 10:36 AM | #9 |
yes all parts are still with us!
02-13-2007, 10:42 AM | #10 |
ok I'll tell my friend.
02-14-2007, 09:22 AM | #11 |
Do you still have your frame rails.
02-14-2007, 09:51 AM | #12 |
yes all parts are still avalible.
02-14-2007, 10:27 AM | #13 |
CouldI get some closeup pictures of the frame rails.Thanks
02-15-2007, 07:24 PM | #14 |
Junior Member
I'll try get some more pict's this weekend
02-16-2007, 09:09 AM | #15 |
Ok Thanks.
03-22-2007, 08:30 PM | #16 |
Junior Member
ttt
03-22-2007, 08:44 PM | #17 |
Are you cutting any parts yet, I tried to call Jim on the phone but didn't get ahold of him. I need to get some cab mounts and a crossmember (behind cab) Thanks...
03-22-2007, 11:39 PM | #18 |
do you have the u bolts and spring plates for the rear end, if so how much
thanks Shawn |
