01-28-2007, 10:13 PM | #1 |
Junior Member
fan motor speed issue
Wondering if anyone else has ran across this issue. I'm trying to get my AC/heater to work. Initially, I was getting power to the motor, but the motor wasn't coming on. The motor worked fine when off and tested on a battery. I put it back on and cleaned/tightened all the grounds and it now works. That was probably just a grounding issue.
Now my current problem. When I turn the switch on low and medium speed works fine however, when I put it in high it goes back to low or off. Anybody have any ideas? I thought it might be the relay or resistor, but I thought I would ask you guys first. Thanks in advance. M |
01-28-2007, 10:53 PM | #2 |
Junior Member
Re: fan motor speed issue
New question--I was reading some older threads on this subject and found some mentioning a high speed relay. I know where the one is near the glove box, but where is the "high speed" one located? Could that be my problem. By the way this is a 70 K20 AC truck. Thanks, M
01-28-2007, 10:57 PM | #3 |
its all about the +6 inches
that one under the glove box is the relay you are looking for. Odds are, it is the problem.
01-28-2007, 11:10 PM | #4 |
Firefighter
The blower motor resistor could also cause this type of problem
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
01-29-2007, 12:32 AM | #5 |
The resistor assy reduces the voltage at low and medium speed. High is the full 12V. If the motor does not run on high when in the truck you need to check the connectors @ the resistor and/or at the switch. Also it is possible that the switch is bad.
Check this thread for the wiring diagram: http://67-72chevytrucks.com/vboard/s...d.php?t=185665
Oscar '72 Shortbed Fleetside '95 Jimmy 4X4 '69 GMC Custom Camper Last edited by FLEET72; 01-29-2007 at 12:32 AM. |
01-29-2007, 07:54 PM | #6 |
hogrocket
Mine had the same issue and it was the ground from the relay. It is behind the glove box up high on the firewall between the heater box and the passenger side wall. It is a short wire that allot of folks do not properly attach after a heater coil replacement. It is a very short wire and easy to get left off.
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
