TH-400 in 69 GMC 1/2 ton
The truck had a 3 speed on the colum, but uhh...im packin big power so i had to get a big nasty tranny. I've heard of needing to move the cross member back to get it to mount up. How far do i need to move it back? Thanks-
Greg
If it don't lope...well...it sucks. |
its all about the +6 inches
Re: TH-400 in 69 GMC 1/2 ton
You'll need to OBTAIN a cross member. The 3 speed has a totally different set up.
NOT REALLY BANNED!
![]() Join Date: Jul 2004
For a TH400, you'll need the crossmember, the donor trucks driveshaft, the column, the shift linkages, the list goes on.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
rad, cooling lines, kick down switch (on carb) and wiring, and the hard line for the vac modulator.
