Old 01-29-2007, 12:21 AM   #1
ocbaud
Garage Queen Material
tranny cooler lines
in regards to :
http://73-87.com/7387garage/drivetrain/tranny_hoses.htm
mike has almost the same tranny cooler as i do, but mine doesnt have the threaded in/out ports on it, just a nipple.
my problem is after a while, the rubber hoses that connect the cooler to the stock metal lines, they start to deteriorate and leak quite a bit.
i'm wanting to add actual fittings instead of hose clamps that it has to use.
whats the easiest way to fix this problem besides buying a new tranny cooler???
ocbaud is offline   Reply With Quote
Old 01-29-2007, 08:52 AM   #2
rcbildr
rcbildr's Avatar
Re: tranny cooler lines
A long time ago I was working on this for my old 71 chevy. I plan on doing something similar on my 67 Burb.
Try finding a place that specializes in hydraulic fittings. I think if you bring in your tranny cooler they should be able to get you set up. I think you will have to use the type of fittings that use a metal ferril (sp?)...I think they are called compression fittings. I've used them at work for high pressure hydraulics and stuff.
It's been a while since I checked, but I think summit or jeg's has a tube to AN fitting adapter...just not sure if it is the right size. Hope this helps.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 01-29-2007, 12:40 PM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Are you using hose that is rated for ATF? If you use fuel line, the ATF will eat it up. Mine is put together with rubber hose rated for ATF and hose clamps, and I have never had any trouble. It was that way when I got it 5+ years ago, and I only replaced the hoses once when I had everything apart. The hose is available at auto parts stores, usually in the same section as the transmission coolers.
Sorry I didn't actually answer your question...
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 01-29-2007, 12:54 PM   #4
ocbaud
i'm sure they are atf rated, they came with the cooler.l
Old 01-29-2007, 12:56 PM   #5
redz 1970 K5
OBS guy
redz 1970 K5's Avatar
Oh, great... Just a note of things to come, since I just installed a B&M cooler with the slip on fittings. I will be looking forward to that one in the near future.
88 Suburban
Goodies- Alpine, Auto Meter, BDS, Bilstein, B&M, BFG, Borgeson, Bushwhacker, Cowl hood, Flowmaster, Genuine Gear,
Holley, Infinity, JVC, K&N, MB Wheels, MSD, Pioneer, Skyjacker, Sony, Thorley, Walker + more
redz 1970 K5 is offline   Reply With Quote
Old 01-29-2007, 02:39 PM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
I have had a trans cooler with slip on fittings on my truck for quite some ($ years) time and have had no leaks. Definitely check the type of tubing that you are using.
piecesparts is offline   Reply With Quote
