Old 08-26-2002, 12:12 PM   #1
darrel_s
darrel_s's Avatar
Intake Manifold?
Thinking of refurbishing my original intake manifold. There is alot of carbon buildup that breaks off and falls out from under this plate. It is held on by what looks to be rivits. Question is can If I break these rivits in order to remove and clean the underside, how can I reattatch this plate. Drill and screw back in place? Thanks
darrel_s is offline   Reply With Quote
Old 08-26-2002, 12:46 PM   #2
COBALT
COBALT's Avatar
I did just this same thing a couple of months ago. My advice to you is to let the machine shop handle it. They'll pull the rivets, clean the manifold, and reattach the plate with new rivets.
Get the yellow pages and look up a machine shop locally that does engine cleaning. Look for a place that offers two kinds: hot tanking and furnace firing. Avoid shot peaning, because those little beads are a ***** to get out once you get the manifold back (just my opinion).
I had mine furnace fired. It was a greasy oily intake off of a 327 that I got from LeRoy. It cost me $36 to have the old carb studs pulled, new ones put in, the oil shield removed and reattached (that's what that "plate" is -- keeps the oil from boiling in the lifter valley), fired and cleaned and ready to go. It looked brand new when I got it back, so it was worth every penny.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 08-26-2002, 01:31 PM   #3
JimKshortstep4x4
Smile
We knock the rivets out with a chisel, tap the holes with an 8-32
tap, and after cleaning, screw the cover back down with 8-32 ss
screws. Unless you use a bottoming tap, you will hit the unfinished threads at the right depth and it locks the 1/2" long screws into place so they won't back out. The holes are the right size for tapping 8-32. Sometimes you have to play with the thread depth to get enough threads to tighen up the cover before the threads lock.
Jim
Jim
