Old 01-29-2007, 04:46 AM   #1
dangould
converting 49 3100 to 4X4
We have a 49 3100 body and chassis that has been in the family since it was new. It is not functional now at all. We want to update it. Some of the changes include an automatic 4X4 transmssion/drive train. Is it possible to make this change on the current chassis or as an alternative, is it possible to put the body on a newer chassis that has or accommodates the transmission and drive train we want?
dangould is offline   Reply With Quote
Old 01-29-2007, 09:12 AM   #2
entourageguy
Yellow truck club
entourageguy's Avatar
Re: converting 49 3100 to 4X4
I believe s-10 reg cab long box is used quite often for this conversion
Brian ..
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 01-29-2007, 11:56 AM   #3
49studebaker
49studebaker's Avatar
In the long run, you will be better off using a different chassis. There will be so many modifications to your existing frame, not much of it will end up being "stocK", once you're finished. I like the S-10 idea. Lots of conversion parts out there for small block chevy to S-10 chassis. The with should be just about right also. Plus a newer frame will hold up to the added weight and power. Easy way to get power steering, disc brakes, the list goes on. Besides, wore out S-10's are rather reasonable price wise.
04 4x4 GMC Ext. Cab lifted
71 2wd GMC / Ramjet 350 ready for sheet metal
49 Studebaker pickup
49studebaker is offline   Reply With Quote
Old 02-01-2007, 10:48 AM   #4
dangould
Thanks for the quick input!
Old 02-01-2007, 05:45 PM   #5
cobinder
Everything is work in progress
cobinder's Avatar
and your 49 frame really isn't setup for modern power and 4x4 loads. Your leaf spring mounts are too short so you have to extend your already smallish frame forward to fit modern springs on. just my 2$ worth
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
