Old 01-29-2007, 09:35 AM   #1
fade94
fade94's Avatar
Need pics of aftermarket buckets..
I have a set of Regency leather buckets that I would like to put in my 71. The tank will be coming out. Looking for pics of trucks with aftermarket buckets and more importantly, the mounting set up you used.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 01-29-2007, 10:09 AM   #2
67chevemall
67chevemall's Avatar
Re: Need pics of aftermarket buckets..
My 91 Acura intergras just needed the metal on the four ends of the seat tracks bent straight out and new drill holes for new bolts. Go for it
tip use longer bolts and pull the metal together then put smaller bolts in .
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 01-29-2007, 11:50 AM   #3
jimmydean
jimmydean's Avatar
If you can bend some steel, you can get about any seat to fit. Every seat I've dealt with has had straight runners with some bracket riveted to them. Cut the rivet out, make a bracket that puts the seat how you want it and your done. I've used carriage bolts for the runners and regular bolts for the mount and never had issues.
jimmydean is offline   Reply With Quote
