Cam
Hey guy's can anyone one tell me about what kind of cam i have.
Well here are the spec's: Comp Cam part # 08-423-8 Duration @ .050 intake - 224 exhuast - 230 lobe lift .3350 .3400 lobe speration 110.0 Thanks JD |
Re: Cam
Looks like you already know!
Rudy Fierros '95 Honda VFR750F Used to have a '71 Chevy Stepside, Guards Red, Lowered 4" rear, 3" front, White Oak bed wood, 700R4 w/373 gears until some low life stole it! |
Re: Cam
call comp cams tech line they should know
Re: Cam
I'm going to take a guess at this one.
110 lobe separation tells me this is a streetable, pump friendly cam with a little "lope" to it. .502/510 is a dual pattern cam with an RPM range from 1500 to 5500. The grind is also a good street power maker that can pull a boat or light up your tires from the light. Over all, looks like a good all around cam. That's my .02 worth.... By the way... welcome to the board from snowy Colorado. I'm sure someone with more knowledge than myself will be able to further enlighten you. ![]()
The Fastor Pastor '68 swb, 447 BBC/ 6-71 Weiand, Dual 950 Bigs Carbs/ 2 1/2" Header tubes - 4" collectors/ M-21 4speed: '70 swb; TH-400 - bagged & shaved. Looking for new engine or parts. Wife - Original {A Real Classic!} ![]() |
Re: Cam
![]() http://www.compcams.com/Technical/Se...umber=08-423-8 Pretty lusty cam for a 350 ![]() |
Re: Cam
Thanks guys but I guess I should be a little more clear, is this cam a small cam, a mild cam, or high powered cam? I know nothing about these cams and I just wanted to know what I had....
Thanks |
![]() Join Date: Jul 2005
Re: Cam
The biggest problem people have, is other people Thou shalt be cool and not hassle ![]() Be a site supporter. ![]() The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
