Old 01-29-2007, 01:30 PM   #1
67cruiser
67cruiser's Avatar
steering box
I've got a 67 c10 and my steering box is real loose. I've posted a thread about it a couple of weeks ago. Well I tried to tighten it up but that didn't seem to work. Also somebody told me to check the fluid level in it but can't break the bolts loose not sure even if it was low if it would solve the problem. So I was wondering do they sell a rebuild kit for these or is it not worth the hassle. Should I just go buy a new one , they are very pricey or is there another model vehicle i could pull one at the scrapyard and use it. Or does anybody got an extra one they are looking to get rid of. Thanks!
67 C10 SWB
350-Turbo 400 tranny-Disc brake
"Those who live by the sword get shot by those who don't"
67cruiser is offline   Reply With Quote
Old 01-29-2007, 01:34 PM   #2
jhow66
jhow66's Avatar
Re: steering box
Manuel or power steering?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-29-2007, 01:36 PM   #3
67cruiser
67cruiser's Avatar
Re: steering box
Power steering.
67 C10 SWB
Old 01-29-2007, 01:41 PM   #4
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: steering box
it's most likely you front end components that need replacing. ie: ball joints, inner/outer tie rods, etc. I'd replace those first, or at minimum check them for excessive wear.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 01-29-2007, 04:02 PM   #5
67cruiser
67cruiser's Avatar
Re: steering box
It's got all brand new tie rods, ball joints, everything but steering box and drag link.
67 C10 SWB
Old 01-29-2007, 04:19 PM   #6
72lb4x4
Re: steering box
Did you check or replace/rebuild the rag joint yet?
72lb4x4 is offline   Reply With Quote
Old 01-29-2007, 04:48 PM   #7
68speedalert
Semi-Senior Member
68speedalert's Avatar
Re: steering box
Originally Posted by 67cruiser View Post
.... Also somebody told me to check the fluid level in it but can't break the bolts loose not sure even if it was low if it would solve the problem..........
What??????
You've got power, what bolt are you trying to loosen to check it?!?!?!
Just use the dipstick on the p/s pump!
Have someone rock the steering wheel back and forth, about 4-6 inches. Look for any side to side movement in any of the tie rods & pitman arm (off steering box).
Check for looseness in the rag joint or any of the steering rod coming from the column.
Check if the box is loose from the frame.
Do this with the engine running.
How much play? Stand outside the truck with it running while rocking the wheel back and forth. Measure how many inches the wheel moves from front tire movement one direction until it starts to turn the other direction.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 01-29-2007, 06:28 PM   #8
john
member #16
john's Avatar
Re: steering box
Do you have the 67 style P.S. with the cylinder on the center link? Or the newer style? I think most have been updated.
john is offline   Reply With Quote
