Old 08-26-2002, 12:33 PM   #1
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
Electric choke on Q jet? (More Q's added)
Is there an electric choke for my Quadrajet. If so, where do I get one? I'm going to use my truck as a daily driver in the winter so I need to have a choke. My neighbors would really appreciate it if I didn't have to rev my engine every morning at 5am and it would be nice to be able to start my truck and walk away while it warms up.
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 08-26-2002, 01:03 PM   #2
JimKshortstep4x4
Smile
We used a Q jet off of an 81 Chevrolet which has an electric choke on it and it works great. We used the HEI 12v feed for the power on his 70 truck. I have not seen an aftermarket setup for the Q jet, but anything is possible.
JIm
Old 08-26-2002, 02:22 PM   #3
mikep
Used to have a truck
mikep's Avatar
There are kits available. Theyre fairly pricy at around $70 or so. I went looking for one several months ago and found a few companies that offer them. Most were somewhat hokey setups that bolted an electric choke coil and housing to the manifold and used a rod to connect to the choke lever on the carb. Why not just go with a divorced choke setup? edelbrock sells a kit that bolts onto the hot air boss on their manifolds and it also works on cast iron manifold. I have one on my cast iron chevy manifold ( Later model canadian spec without EGR and with hot air choke boss) and it works great .
No truck :-(
mikep is offline   Reply With Quote
Old 08-26-2002, 02:53 PM   #4
Fast68Chevy
Fast68Chevy's Avatar
depend son what year carb you have, electric wasnt invented til around 76, and there are no real true provisions on our carbs for electric, except aftermarket really, best bet is to go rob an electric choke model off a 76 or so and newer GM car or truck
good luck
Fast68Chevy is offline   Reply With Quote
Old 08-26-2002, 05:28 PM   #5
70 Jimmy
70 Jimmy's Avatar
Sounds like I have options. Does anyone have pics of these set ups? When it comes to these carbs, I'm clueless.
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
Old 08-26-2002, 10:46 PM   #6
racedvl
racedvl's Avatar
It's the black part off to the left. This carb is a 81/82 vintage I beleve.
racedvl is offline   Reply With Quote
Old 08-26-2002, 10:47 PM   #7
racedvl
racedvl's Avatar
Sorry, I ment right. My other left. LOL!!
Old 08-27-2002, 07:28 AM   #8
JimKshortstep4x4
Smile
I am always amazed at how quick pictures are posted on the board. Pictures can be really helpful and the detail is usually great!
Keep it up!
Jim
Old 08-27-2002, 07:49 AM   #9
Mike C
Mike C's Avatar
JC Whitney has electric choke conversions for about $30. May not be worth it depending on the condition of your carb. I have a couple of JET stage II 750 Q-jets, one on each of my trucks, and they rock and have electric chokes. Easy swap onto the '72 with its cable, but required mods to work with the mechanical linkage on the '70.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 08-27-2002, 10:01 PM   #10
sub4rvr
sub4rvr's Avatar
I bought the same part that racedvl has at the swap meet for $5 new. Hygrade is the brand, part # CV300 Choke Thermostat.
72 C10 Suburban
90 S10
57 F100 (2)
67 Mustang (2)
69 Torino GT
00 Mustang GT Conv.
sub4rvr is offline   Reply With Quote
Old 08-27-2002, 11:21 PM   #11
70 Jimmy
70 Jimmy's Avatar
Thanks guys. My carb is in great shape. I doesn't even leak! Eventually I'll go with Edlebrock or Demon (it's all about money!) but for now, it's the Quad.
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
Old 08-28-2002, 10:38 AM   #12
6869704X4
Can I have the Quad when your done with it?
Have you thought of a manual choke? Much cheaper. And you have full control. I can put up a pic if you want.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
