Old 08-26-2002, 12:37 PM   #1
Travis Byrne
Installing Headliner Trim
What all is involved in istalling the headliner and trim in a truck that did not come originaly with a headliner? Thanks Travis.
1972 Custom/10 Longbed In the works
Travis Byrne is offline   Reply With Quote
Old 08-26-2002, 12:51 PM   #2
Gene
Gene's Avatar
Hey Travis, I was thinking about installing trim in my truck but after finding it at a salvage yard and re-chroming(not actually chrome) the trim I found out it was more trouble than it was worth. Don't get me wrong but you would have to find a truck that came equipped with it and cut slots in your truck to exactly match those in the trim. There are slots on the front and sides and only I believe 2 screws that hold it all in. It is possible so if you decide to do so good luck. Gene
Gene is offline   Reply With Quote
Old 08-26-2002, 01:10 PM   #3
Mudder
Mudder's Avatar
I did it!
Came out very nice and have had no problems. I bought new trim, broke the tabs off and used screws to attach. Just be very careful and use short screws so u dont go through your roof. New trim comes with screw holes in it already. I bought a very nice headliner in KC for 50 bucks and painted it black.
Mudder is offline   Reply With Quote
Old 08-26-2002, 01:29 PM   #4
Travis Byrne
What lenth of screw should I use? Did you drill your holes in the roof first? The trim I have has screw holes at the conection joints. SHould I ad more?
Old 08-26-2002, 01:36 PM   #5
Mudder
Mudder's Avatar
I used
12 screws. I also use a 2 sided tape to help hold th eheadliner up while I put the trim on. Duct tape worked good for holding trim in place while you work with it. DO NOT USE anything longer than 1/2 inch! Be careful!
Old 08-26-2002, 01:55 PM   #6
Travis Byrne
Thanks for the info. I will give it a try. and be very careful.
Old 08-26-2002, 01:57 PM   #7
Gene
Gene's Avatar
Good idea, didnt even know it was available new I still have the headliner. Guess i'll take another stab at installing it.
Old 08-26-2002, 01:58 PM   #8
Mudder
Mudder's Avatar
I spaced
the screws out and drilled holes once i got everything stuck up there. Carelessness='s hole in the roof LOL.
Old 08-26-2002, 02:00 PM   #9
Gene
Gene's Avatar
You do still have to glue the actual headliner in thought dont you? I know the salvage yard one had glue on it.
Old 08-26-2002, 02:03 PM   #10
johnnyp
Keepin' It Stock
johnnyp's Avatar
Yes, you have to glue the headline in also or it will sag. Use the strongest glue you can find, like contact cement. I tried a spray-on adhesive and it let go the first time the truck set in the sun for a few hours.
72 Sierra Grande - Maych
Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
johnnyp is offline   Reply With Quote
Old 08-26-2002, 02:20 PM   #11
Mudder
Mudder's Avatar
Tape
that is used for side (outside) trim may work pretty good. Mine doesnt stay stuck very well but it doesnt sag either, that is noticable.
Old 08-27-2002, 01:18 AM   #12
Gee_Emm
hehehe, I made all of those little oval holes in a cab that didnt come with a headliner, to do this you need a cab right beside you that had the headliner option, little files, a drill and ALOT of patience.
Gee_Emm is offline   Reply With Quote
Old 08-27-2002, 01:38 AM   #13
slam33
slam33's Avatar
Sport Truck Mag, Jan 2001. Tape the trim to the headliner and the whole thing to the cab roof. Be sure to mark where the tabs are on the tape. Transfer those marks to the roof. The tabs are about 1/4 inch long, mark the holes for a 1/2 long so you have some play. The holes are centered in the raised roof line. Use a 7/32 drill and dill the hole at each end of your marks, don't go thru the roof. Cut out the metal between the holes with a cut off wheel. Check all the holes of the tabs to make sure the tabs will fit. Glue the headliner in, install the molding the drill the screw holes and put in the screws. Getting ready to do this one myself this weekend.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 08-27-2002, 05:41 AM   #14
Travis Byrne
how well will 3m spray 90 adhesive work to hold the headliner in?
Old 08-27-2002, 08:38 AM   #15
Jeff M.
Jeff M.'s Avatar
Travis, my stock headliner saged for years. I finally took it down and used the 3M Spray Adhesive. Sprayed both the roof and the headliner. Stuck up there and looks great. This was about 2 years ago and it's still flat on the roof even in this 100+ degree weather.
69 C-10 CST Short Fleet, Factory Air, BB427-400 Auto-2400 stall-tilt-cruise-Tach & Vac Gagues, 4/6 drop, power one piece side windows, Eaton posi.
Jeff M. is offline   Reply With Quote
Old 08-27-2002, 04:50 PM   #16
johnnyp
Keepin' It Stock
johnnyp's Avatar
Travis, the spray-on adhesive I used was made by 3M but it wasn't the "90" (must of been 45, LOL) If Jeff's been on for two years, it must work ok.
Old 08-28-2002, 08:49 AM   #17
Billy Porter
2" velcro will keep it in place even without the trim pieces
71 GMC Stepside
250/350 Turbo better known as "Fred Sanford
77 240 Mercedes Benz
92 300E Mercedes Benz
70 Firebird 400
85 600 Ninja
Billy Porter is offline   Reply With Quote
