Old 01-29-2007, 03:37 PM   #1
cgoodwin
cgoodwin's Avatar
Red face transmissions?
I've posted before that I have a turbo 350 tranny in the truck and just don't like not having that overdrive. Here's the question:
can the turbo 350 and go with something else or look into the gear vendors unit and keep the turbo 350?
Like most of us, I'm trying to get the best of both worlds. Good gas mileage and that big pull from a stop. The one thing I do know is I will be moving away from the 411 rear gear and down to 308 or 342.
cgoodwin is offline   Reply With Quote
Old 01-29-2007, 07:15 PM   #2
cooters
Re: transmissions?
optimum gear with an overdrive is 373, with a 235 type tire. Dont go with an overdrive and less gear unless your motor makes good torque. A 700 is still cheaper than the vendors unit. 700 built right is a good choice
cooters is offline   Reply With Quote
Old 01-29-2007, 07:28 PM   #3
Psycho71
Psycho71's Avatar
Re: transmissions?
It's a long way off for me, but I'm gonna go with the Gear Vendor unit, 3:73's, and a TH400. It should pull good thru 1st, and like a monster when I start splitting gears. And if I don't wanna, I don't have to split gears, then just use O/D when needed. Those things look like the greatest thing since sliced bread. Provided I don't have to take out a second mortgage when the time comes.
But yeah, I wouldn't back off on the gears until after I put in the O/D!
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 01-29-2007, 07:44 PM   #4
wheels67
wheels67's Avatar
Re: transmissions?
Ive got the setup psycho described, and a gear vendors unit will be a permanent fix for my truck...ive seen em used on ebay for 1500dollars.
Imagine 6 gears ..........killa.
wheels67 is offline   Reply With Quote
Old 01-29-2007, 08:02 PM   #5
corn
Re: transmissions?
What does it cost to have a 700 built right? Ive had pretty bad luck with them & have had very good luck with both TH trannies. Way cheap to rebuild too. Im just wondering if a "built right" 700 will cost close to what the gear vender costs, Id go with the gear vender unit.
corn is offline   Reply With Quote
Old 01-29-2007, 08:37 PM   #6
cooters
Re: transmissions?
1000.00 builds a 700 that will take 400hp without a problem. I know it is hard to find a good tranny guy, there have been lots of 700s built to take 1000hp so i believe they have been studied to death. I build my own and dont have to worry.
Old 01-29-2007, 10:06 PM   #7
cgoodwin
cgoodwin's Avatar
Re: transmissions?
so you guys think a set of 342 gears with the turbo 350 and then eventually get the gear vendors unit is the smart move?
