Old 01-29-2007, 03:56 PM   #1
ClassicRedneck05
ClassicRedneck05's Avatar
Exclamation Timing Question?
ok i have a 1972 Chevrolet with the Stock 350 with a Qjet. intake heads block and all i do have headers in it as well as the edelbrock dress up kist (which i know does not make a diff)but the guy who had the truck before me said it has a mild cam in it im wondering what the timeing set should be on it can anyone give me this info
Redneck Rampage
1972 Chevrolet C-10 LWB 350
1972 Chevrolet K-20 LWB 502 LiFtEd
ClassicRedneck05 is offline   Reply With Quote
Old 01-29-2007, 04:20 PM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Timing Question?
What are you running for timing now? Does the truck have an HEI distributor, or is it still the older points style dizzy?
I usually start my engines at a 10 degree intial timing setting and then work my way up from there. I purchased a timing light with the advance feature on it and since then I now set my timing at a "TOTAL ADVANCE" number of 35 degrees or in that area. I also set my idle adjustment screws with a vacuum gauge, rather than just listening to idle speed change, to get the best idle mixture set up for daily driving.
piecesparts is offline   Reply With Quote
Old 01-29-2007, 04:25 PM   #3
ClassicRedneck05
yes i have HEI dis in it and i have an older timng light one that hooks to the pos and neg of the batt then a lil spring that goes on the tip of the plug then the other end into the boot then another wire that connectes to the spring from the light right now its at 0 and i dont have a tach to find out what the RPMs are set at i would like to get my timing right and then the idle right
Redneck Rampage
Old 01-29-2007, 07:07 PM   #4
cooters
as much as this has been a thread issue before, i still say the balancer marks are never on the money and power timing is the best for your application.
cooters is offline   Reply With Quote
Old 01-29-2007, 09:46 PM   #5
piecesparts
With what you have for a timing light, I would pull the vacuum hose and plug it, set the timing at 10 degrees BTDC, put the vacuum hose back on and then drive it. The next thing that I would do, is to advance the initial timing to 12 degrees and drive it again. Listen for spark knock or pinging under acceleration, also look for engine "Run-On" when you shut it off. I would expect that you will settle around the 12 to 15 degree timing area. This will give you a good operating area and a decent performance. Take time to mark your timing marks on the balancer so that it is easy to time the motor, the balancer is fine at this point.
If you decide on a different timing light, at some time, Sears sells an excellent advance unit for a really decent price.
Old 01-30-2007, 12:35 AM   #6
timcos
Chief Honcho In Charge
timcos's Avatar
Here is a nice FAQ on timing
http://67-72chevytrucks.com/vboard/s...ad.php?t=62040
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 02-08-2007, 09:07 PM   #7
67chevemall
67chevemall's Avatar
Good info..keep it coming...can never know enough about the timing
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
