Old 01-29-2007, 07:19 PM   #1
Rc 415
Flat Black, & Chrome!
Rc 415's Avatar
Wiring radio, Constant power lead?
I'm trying to install an Alpine deck into my 83 c10.
The only wires that are behind my dash for the radio are the gray, black, and yellow. Right now i have the battery lead and constant lead from the radio both connected to the yellow wire in the dash, and the ground connected to the ground. I do not have the gray wire connected. The problem is, I cant save presets and the time, because every time I turn the truck off they get reset due to the constant wire not being connected right. What am I supposed to have the constant wire connected to?
Rc 415 is offline   Reply With Quote
Old 01-29-2007, 07:59 PM   #2
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Re: Wiring radio, Constant power lead?
Sounds like you have the radio's constant lead connected to the truck's switched (ignition) power, the yellow wire off of the accessories. It should be connected to a constant power source. The gray wire from the interior lights should provide a constant power source for the radio's memory.
Edit: The gray wire is a switched power source from the headlight switch.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 01-29-2007, 08:02 PM   #3
Rc 415
Rc 415's Avatar
is there a fuse for that gray lead? because I tried it like you say, yellow to yellow, red to gray, black to black, and I got nothing, no power.
Old 01-29-2007, 08:05 PM   #4
cochino12
It followed me home?
cochino12's Avatar
run the yellow from your new radio to a 12v + constant in the fuse box
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-29-2007, 08:07 PM   #5
boxrodz
boxrodz's Avatar
Yes, I believe that interior lights should have a fuse. Follow the interior lights circuit in the schematic. If you have a volt meter, you could check the leads from the truck to verify the power sources and ground. (I don't have my shop manual at the moment.)
boxRODz
Old 01-29-2007, 09:07 PM   #6
Rc 415
Rc 415's Avatar
I wish I had the schematic, of a volt meter even, lol.
Old 01-29-2007, 09:19 PM   #7
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
what i did in my truck was run a constant from the fuse box use yellow for power and blck for ground. Grey will be left empty cause i believe the had on the stock harness yellow=power, black=neg., and grey=ground ( i think)
Srubydo1986 is offline   Reply With Quote
Old 01-29-2007, 09:19 PM   #8
mySAVIOReigns
Active Member
mySAVIOReigns's Avatar
I used the wires out of my cigarette lighter - I'm not a smoker, and I don't even think it worked...but I used those wires to wire it in. It had the ground, the red, and the yellow.
Website Here
-Stephen
1985 Chevy Silverado, 1/2 ton
mySAVIOReigns is offline   Reply With Quote
Old 01-29-2007, 09:24 PM   #9
Rc 415
Rc 415's Avatar
Awsome thats a great idea, thanks!
Old 01-29-2007, 09:25 PM   #10
Rc 415
Rc 415's Avatar
Actually the gray is for the lights that were inside the original radio, but you are right its left empty.
Old 01-29-2007, 10:41 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
If you can't afford a VOM then buy a cheap test light. If you have a soldering iron you can make your own with any 12v bulb and an old jumper wire. It will save you a ton of time knowing when a contact point is hot.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-30-2007, 01:21 AM   #12
boxrodz
boxrodz's Avatar
I checked the wiring schematic and, as you found out, the gray wire is switched power from the headlight switch. Only constant if you keep the lights on.
As Cochino suggested, you can tap into the Batt lead on the fuse box, or just tap into one of the orange wires (lighter, horn, dome light, clock, etc) like some of the others suggested.
BTW, you can find a cheap VOM for ~ 10 bucks.
boxRODz
Old 03-03-2007, 06:25 PM   #13
Rc 415
Rc 415's Avatar
I just tried the cig lighter connected to my constant lead, but the radio still gets reset every time i turn it off and on???
1983 Chevy C10 Stepside Sold
http://s69.photobucket.com/albums/i76/rc_415/
Old 03-03-2007, 07:32 PM   #14
Mickey_D
Dirteh Kitteh
Mickey_D's Avatar
Then swap the yellow and red wires.
Darrin
1955 Willys CJ-5 all original and the oldest CJ-5 on the road.
2001 Dodge Neon (wife's car)
1995 Jeep Grand Cherokee Limited Edition SOLD
1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD
1993 S-10 4X4 Tahoe SOLD
Sign up with the Contact List
RIP ESLL
Mickey_D is offline   Reply With Quote
Old 03-03-2007, 08:29 PM   #15
Rc 415
Rc 415's Avatar
Lol yup I realised that about an hour ago!
