Old 01-29-2007, 07:27 PM   #1
MT1972cheyenne
MT1972cheyenne's Avatar
Hood hinge problems
I have had quite a few of these pickups, and have figured out how to deal with quite a few quirks of this body style, but one I haven't figured out is the hood hinges. What is the best way to adjust them? I can never get the rear of the hood to sit down flush with the cowl or back of the fenders. Are my hinges just worn out?
MT1972cheyenne is offline   Reply With Quote
Old 01-29-2007, 07:35 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Hood hinge problems
They may be.I have had good luck with getting them better by loosening the bolts to the fender,leave them snug enough to stay in place.Open the hood and lift up on the frontpush it up until the hinges slide as far as they will.Tighten the bolts and close the hood slowly making sure it doesn't hit at the cowl.I usually use a 2X4 cut to length to hold some tension while tightening the bolts.This will usually help the rear of the hood set down closer to even with the cowl.Someone else may chime in with more insight than I have.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-29-2007, 09:27 PM   #3
Bob B.
I think you are right on the money. Usually, if the back of the hood sticks up above the cowl, and the hinge to fender adjustment is down all the way, it is because the hinge pivots are worn out.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 01-30-2007, 07:30 AM   #4
Shock_Me
Shock_Me's Avatar
I've used the method described by PanelDeland, and it works great. There is a post by "Huck" somewhere that gives you all the steps required to do the job. Try this first before you order new hinges.
Good luck,
Pete
Shock_Me is offline   Reply With Quote
Old 01-30-2007, 10:56 AM   #5
71MUTT
Can't ReMember
71MUTT's Avatar
One time ,about 10 years ago, I was driving down I-4 in the Orlando area and my hood popped up!!!!!! Thank god I was in the slow lane. Cars were bumper to bumper. The hood was down, but evidently it didn't latch. The wind caught the bug deflector and up she went.
Needless to say, ever since then the huge looking rivets in the hinges have been sloppy and the hood stays up at the cowel only on the left side. I bought a couple of used ones from the junk yard a couple of weeks ago, but haven't installed them yet in fear that I might need new fenders also. One job always leads to two more.
Adversity doesn't test your character; it reveals it.
71 C-10 LWB 350/TH350. I purchased it in 1978 for $1400. I'm currently abusing it daily. (when it's running )
71MUTT is offline   Reply With Quote
Old 01-30-2007, 11:14 AM   #6
Aarons72s
71mutt you can change the hinges by your self. You need a couple of 2x4's to make it quick. Take 1 2x4and place on the cowl under the hood and the other end onthe engine. Having the hood rest on the 2x4 after you remove the hinge. Then remove 1 hinge at a time and replace. Then just adjust the hood. I have mainly done this as a down adn dirty way to replace fenders on trucks.
Aarons72s is offline   Reply With Quote
Old 01-30-2007, 11:19 AM   #7
RedZ71
Junior Member
RedZ71's Avatar
huh, i thought you were just supposed to just sqwush it down after you lower the hood
RedZ71 is offline   Reply With Quote
Old 01-30-2007, 11:19 AM   #8
67ChevyRedneck
67ChevyRedneck's Avatar
Now that my truck is done, I only pop the hood a couple times a month. I use the "push it down" method.
1.Close hood
2.Push down on rear driver side of hood
3.Push down on rear passenger side of hood
Hood is now flush Steps 2 and 3 can be done in reverse order.
I tried the methods described above but could not get my hood down in the back. It helped some, but not enough. I think my 40 year old hinges are shot
If you don't get the other methods to work, mine works great until you pop the hood again
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-30-2007, 11:20 AM   #9
67ChevyRedneck
Posted at the same time, but you beat me to it
Jesse James
Project "On a Dime"
Old 01-30-2007, 12:23 PM   #10
71MUTT
Can't ReMember
71MUTT's Avatar
That's what I used to do, but guess what, now it pops back up. You think it's trying to tell me something? (the old bastard )
Thanks for the tip, Aaron.
Old 01-30-2007, 12:32 PM   #11
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
I would replace the hinges and springs. I have done that to a few trucks and the hoods even pop up a few inches when you depress the latch. (like they did when new) Don't buy the repop hinges though, because they are only 1/2 the thickness of original GM. We have them for $69.95 each and $9.95 for the springs if interested. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 01-30-2007, 05:14 PM   #12
powell72
powell72's Avatar
That's good to know, thanks Wes. I've been tempted to buy the cheap ones before.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 04-15-2007, 09:22 AM   #13
ChevyDude
GM Parts Direct has brand new Hood Hinges...just got some. Springs are not made anymore.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 04-15-2007, 10:30 AM   #14
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Arrow Re: Hood hinge problems
I just went thru this with my 67 but had prior knowledge of this and by that I mean that this problem is a problem that affect's most anything on a car or truck that open's and close's , the other day I used the above mentioned way of aligning the hood and got it near perfect , after that I installed my new hood to cowl rubber seal and the seal being fresh and stiff made the back of the hood stick up , I took the other day off work and it was nice out so I backed my truck out in the hot sun and kept the hood closed while I was doing some other work and by the end of the day it was back down almost flush so I figure when I drive it a little it will level out ,
I learned this also on 1967 1968 1969 camaro trunk lid's align them first then put on a new seal , my 67 camaro trunk lid last time I painted the car and put on a new seal took a month to go back down flush ,,
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 04-15-2007, 10:45 AM   #15
LONGHAIR
I know it sounds backward.............but believe me, if you need the back of your hood to go down, you need to raise the back of the hinges. By dropping them down, you are stopping the hinges from reaching their total travel. If you raise them a bit the hood will actually sit lower.
LONGHAIR is offline   Reply With Quote
Old 04-15-2007, 12:39 PM   #16
N2TRUX
Happy to be here
N2TRUX's Avatar
I would replace the hinges and springs..... We have them for $69.95 each and $9.95 for the springs if interested. WES www.ClassicHeartbeat.com
Wes, do you have them for 73-80 trucks too? My 77 Cheyenne is doing this now. Even when I push the back down it still pops up again.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-15-2007, 01:35 PM   #17
sevt_chevelle
Lost amongst the CORN
sevt_chevelle's Avatar
This place will rebuild your hinges to better then new condition
http://www.hoodhingerepair.com/index.html
Currently working on How To Videos and custom metal
70 Chevelle gettin Sliced and Diced Anything But STOCK
70 Chevelle SS455 not a typo its a BUICK BABY
49 and 72 Chevy Trucks restored to original...close to it
Drommer Stor....Norwegian for Dream Big
http://s969.photobucket.com/albums/a...lle/?start=all
https://www.flickr.com/photos/47922830@N03/
Pictures of my work and projects
sevt_chevelle is offline   Reply With Quote
