Old 01-29-2007, 07:36 PM   #1
wheels67
wheels67's Avatar
Help with original steering ram system.??
Okay, I bought this truck with power steering cylinder bracket busted at the frame mount. Have you guys seen this system before?? On the bottom of the pitman arm is a slave cylinder that distributes the fluid to the weird "shock absorber" looking ram.
The ram is hooked to the steering linkage and the other end goes into a fixed bracket on the frame...(so the ram has something to push against to turn the wheels)
Alright so i welded on a new bracket and ordered a new ram cylinder, it came with 2 rubber bumpers for the fixed side with the threads. Theres a cotter pin in that end also. Question is do i use some large washers on either end of the rubber bumpers...and should i use lock nuts.....please help with a proper mounting pic. Ill try to attach some pics cuz i know we all love em here.LOLOL
wheels67 is offline   Reply With Quote
Old 01-30-2007, 12:02 AM   #2
wheels67
wheels67's Avatar
Re: Help with original steering ram system.??
I hit the search feature and found enough info....
Old 01-30-2007, 08:29 PM   #3
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
On getting it Fixed, From what i gather this type steering set up is pretty rare.................
What did the new Ram cost?
Thanks, Rick
toomanytoyz is offline   Reply With Quote
