![]() Join Date: Jan 2006
Oil filter Question
I recently Id'd my engine and it turns out to be a '76 305. I have been using an oil filter for a 69 307, which is twice as long as the filter reccomended for the 305. Could this have caused any problems or damage to the block ie reduction in oil pressure etc.....what do you guys think?
thanks rick |
Re: Oil filter Question
Nope, your fine. Alot of guys change to bigger filters. As long as the oil was topped off.
i use a 3 ton oil filter which is about a foot long, better filtering a possibly a little better oil cooling. If it fits then bigger is better. Big filter is Fram ph373
Dave's not here, man
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
This is a GREAT filter. It holds 2 quarts of oil. I've been using it for many years. I have only one complaint....it costs about twice as much as the one quart filter.
its all about the +6 inches
are you guys really putting fram filters on your trucks? They are the absolute worst filters on the market. Not opinion here.... fact.
Firefighter
Yes FRAM = Death and Destruction to an engine!!!! It's the only filter that I know of that WILL VOID Factory Warranty on new Dodge and Chevrolet autos!!
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
The dealer will tell you that, however, if they try pulling that on you, get it in writing.
Fram filed a lawsuit on that and won. If your dealer tells you this, then they are required to supply you a filter at no charge to you. Fram totally sucks, and the OEMs hate them just as much, but don't let the dealer screw you over. |
When I bought my 71 Dart the PO used Fram filters and complained about not having any oil pressure. He switched filters and it solved the problem. I guess the Fram filters are designed to filter really small particles and it greatly reduces oil flow?? That could just be jibberish, but it sounded good! I'll bet Longhorn Man knows.....
I can't explain that part of the equation, i have heard it before though.
Fram simply doesn't have enough filtering media in it. Think of it as a tin can with 3 kleenex tissues thrown in it. |
My engine has over 275,000 miles....all with Fram oil filters and still has a compression of 150, runs great, and the engine has NEVER been opened up. You can’t knock success! Rumors, rumers, rumers....I don’t believe them. Show me proof.
FRAM FOR LIFE!!!!
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
#13 |
Designated A-hole!
For proof go to www.bobistheoilguy.com . I know people who have driven furds and had no problems with them.....doesn't make me want to drive a furd.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
#14 | |
In Memoriam...
![]() I was always a Fram user until I was enlightened. I was SHOCKED when I saw the info on this website. http://people.msoe.edu/~yoderw/oilfi...lterstudy.html The info on the above site is geared to Mopar, but the analysis will be the same regardless of the car/truck. Not all Fram filters are turds. The Fram Tough Guard was rated good, but with the really poor performance of the other Fram models, I'd still stay away. This is MUST READ info...
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." |
#15 |
Thanks!!!
#16 |
...... so what is the BETTER filter??
#17 |
In Memoriam...
There are several recommended. This link is the 2nd page to the above link...
http://people.msoe.edu/~yoderw/oilfi...ilfilters.html It give great details on recommended and ones to avoid, and why the recommendations are made.
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." Last edited by FarmTruk; 01-29-2007 at 11:37 PM. |
#18 |
dealer filters are the best, i have had 2 filters colapse on the inside in high horsepower engines about 10 years ago, since then they seem to be working and i do check them. John Force wouldnt stear us wrong, would he?
#19 |
Location: vacaville ca, because it as far from indy as i can be
ive ben useing the fram ph5 and ph8 for 9 yeaers on multiple trucks and motors and never had a problem.
i have had a filter get slapped by a hedder and wear a hole in it but it was a tight fit and then it got bent wheelin. |
#20 |
all I'll say is this.. go get a napa gold filter (P/N 1060) which is nothing but a rebadged Wix filter, and cut it open... then cut open your beloved fram, and you will never screw another one onto your motor.
Yes, you can get 275,000 miles with fram filters.... we also got 265,000 miles on the original automatic overdrive in a ford F-150 in a fleet driven truck that had been abused and beaten... totaled 3 times, and only had the fluid chainged once at 95,000 miles. Anything can happen. however, if you know what you are looking at... and even if you don't know, but just have common sence...crack open the 2 filters and have a look see. Go ahead, spend the 18 bucks to look at them yourself. As far as John Force... even the Rolling Stones sold out. Money talks. |
#21 |
Glad I started using wix.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
#22 |
delco filters aren't bad either. should be a 1218 (1qt) or 932(2qt).
carquest's good filters are also made by wix.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
#23 |
Me I use wix or delco filters, which ever is in stock when I go and buy but usually delco. my dad was a devote fram guy to. Me I always prefered oe. Yah I run the big filters on my truck to. Seems to do better with them. Bigger filter= more oil= happy engine!
#24 |
delco has 2 lines... one is kinda low on the totum pole... not Fram low, but it is down there. The other is way up high like the Wix filters.
#25 |
Does anyone remember when...you could buy a kit for the ol 265 change the oil and install a roll of bathroom paper for an oil filter? Had a uncle that did that for his '54 chevy for years. Must not have hurt anything I believe he got 180-200,000 miles on that old car. Ohh yeah he also used to flush the engine with kersone both oil pan & pour it down the carb reving the crap out of it to keep it from dying to clean the carb..Amazing how far we have come huh?? Gas wars @ .23 plus you got a free coffee cup & a saucer & SS Stamps too!
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
