01-29-2007, 08:24 PM | #1 |
Sierra Grande Club
The writing on the block….
After cleaning off the engine, I found some writing on the block
I found this painted on both sides of the block. What is this? Is this the equivalent to the writing in the firewall bay of Chevy’s? BTY do GMC’s have the writing on them? I have the block numbers and I’m trying to figure out if it’s the original engine or not. 65-72 chevytoys gave me a link to help me with matching the numbers. Thanks, s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. Last edited by Sport/Truck; 10-04-2007 at 08:09 PM. |
01-29-2007, 08:29 PM | #2 |
Gone Fishing
Re: The writing on the block….
Maybe a wreckin yard engine or a rebuilder put those markins there
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
01-29-2007, 09:01 PM | #3 |
Sierra Grande Club
So how does one tell if it’s been rebuilt? I would have thought that the small clips on the oil pan (for the plug wires) would have been MIA. And most likely the heat shield would have been scraped. It was such a PITA to get it off I would wonder why anyone would try to put it on.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
01-29-2007, 09:30 PM | #4 |
Dave's not here, man
The original 307 that came in my truck had .030" scribed into the top of the pistons. Not sure if this is commonplace, but it might be worth checking.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
01-29-2007, 09:31 PM | #5 |
o yea i have seen that before..
stands for TOTALY BADA$$ CHEVY J/K dean. it sounds good tho |
01-29-2007, 09:44 PM | #6 |
If the pistons have 30 stamped in them they are 0.030" over piston so its is rebuilt, look on all the flat surfaces on the block for letters stamped. I know when we rebuild an engine we mark AP(action parts) and then the date of compleation. I think we put it where the oil pan bolts on
01-29-2007, 10:01 PM | #7 |
if you look close you can see "30" near the centre of the piston
01-29-2007, 10:10 PM | #8 |
Sierra Grande Club
Here’s something interesting the TBC is also on the block here.
01-29-2007, 10:19 PM | #9 | |
Sierra Grande Club
What about the stock timing chain? Can someone post a picture or describe what it looks like? could this be a clue? s/t
01-29-2007, 10:26 PM | #10 |
If it has a double timing chain it is not stock
01-29-2007, 10:28 PM | #11 |
Im fairly sure on that, I havent seen it anyways and your looks like it does on the second picture
01-29-2007, 10:30 PM | #12 | |
Weekend Warrior
should be a single chain. Pull a main cap and check the back side of the bearing. if it says "GM 400" or something with "GM" on it - it's probably stock. If it says .001, .002, .010, .020, .030 - then the crank has been cut and messed with. Looks stock to me. Although not common I have seen "paint markings" like that on some Small Blocks. The fact that it matches the Stamping on the Front pad indicates it is probably original. What is the date code on the block: that will narrow it down TBC = 1970 350 convfwd cabs, a/t , 255hp, 4bbl, C-10 to 3500 TBC = 1970 350 m/t, 3 spd, 255hp, 4bbl, K-10 & 20 TBC = 1979 350 conv. cab, m/t,fed L LS9 165hp, 4bbl, C-10 to 2500
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered Last edited by arkracing; 01-29-2007 at 10:33 PM. |
01-29-2007, 10:31 PM | #13 |
Sierra Grande Club
I just replaced it. but the old one was weird looking.
01-29-2007, 10:31 PM | #14 |
That looks like a suffix to me.vi203tbc. There is a way to check suffix at nasty z-28.com
The biggest problem people have, is other people Thou shalt be cool and not hassle Be a site supporter. The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
01-29-2007, 10:37 PM | #15 | |
Weekend Warrior
See above post - I copied the info from NastyZ with the 3 possibilities.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered |
01-29-2007, 10:48 PM | #16 |
http://www.nastyz28.com/gm-chevy-cod...s-suffix-6.php
Click on this link scroll down till you see TCB. Good Luck
The biggest problem people have, is other people Thou shalt be cool and not hassle Be a site supporter. The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 Last edited by larry may; 01-29-2007 at 10:49 PM. |
01-29-2007, 10:52 PM | #17 | |
Sierra Grande Club
01-29-2007, 11:30 PM | #18 |
Sierra Grande Club
Thanks to everyone for the help with this. I took a few pictures of maybe the date code?
And a not so good picture of the main cap, if this could tell us anything I’ll go clean it off and take another one. I’ll be doing the rear main seal so I’ll be able to check for the info for over size on the cap. s/t
01-30-2007, 12:06 AM | #19 |
The block appears to have been produced on the 12 th day of March in the 7th hour of that shift of work .According to the time clock and the suffix. Not sure of the year. Could have been 1969 .Hope this helps..
01-30-2007, 01:15 AM | #20 |
If you go to Ellendale North Dakota you will find TBC (Trinity Bible College)
But i don't think they produce engines or have a signature model
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
01-30-2007, 08:14 AM | #21 | |
Weekend Warrior
anyway in your first picture - where it "looks" like there are tags riveted or screwed to the block - the second one says "L 2 ?" I can't make out the last number - "9" or "0" or "?" L = December 2 = December 2cd ? = Year - if it is a "0" then it would be a late '70 block and correct for your '71 - but it doesn't appear to be a "0" - but I could be wrogn sometimes casting numbers are hard to make out. 9 would be '69 or '79, 0 would be '70 - which would make since according to the TBC
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered Last edited by arkracing; 01-30-2007 at 08:16 AM. |
01-30-2007, 08:30 AM | #22 |
[QUOTE=arkracing;2009150]???? 7th hour of that shift??? where are you getting that? the clock thing only has 10 markings?
Exactly. The pointer starts the shift inside the rivets the rivet outside the circle says what hour of the shift the block was cast. Count clockwise. Do not bother trying to get a pi$$ing contest going . Read the publications .
01-30-2007, 08:44 AM | #23 |
68 C10 Longbed
I'm pretty sure the letters on your block are the engine suffix code which denotes what it is and what it is for. The set of numbers I don't know. It is part of you vin sequence number maybe?
01-30-2007, 09:18 AM | #24 |
Unfortunatly you do not have a numbers matching truck. Ususually the yellow marks are from the grease pens that junkyards use to mark their inventory. The TBC came out of a 1970 truck and the number for the heads you gave me were for 1971 and 1972 only.
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer |
01-30-2007, 09:31 AM | #25 |
I had the original 350 go in my '69 recently and the timing chain was aluminum with nylon,and it had fallen apart and slipped a lot on the cam sprocket.( Why can't they make things that last?) I believe that the O.E. chains were all like this.If you have a regular steel or double chain,it is a re-build afaik.
