Old 01-29-2007, 11:19 PM   #1
rick0312
rick0312's Avatar
Compression Test 1976 305
I finally did a compression test and was wondering if these numbers are good or bad. The test was done on a cold motor. Initial compression on all cylinders came up fast and maxed out at numbers listed.
#2 130 #1 125
#4 130 #3 130
#6 130 #5 135
#8 125 #7 140
injected some oil into #8 cylinder and compression rose to 130.
Thanks for all of your help
Rick
rick0312 is offline   Reply With Quote
Old 01-29-2007, 11:42 PM   #2
FarmTruk
In Memoriam...
FarmTruk's Avatar
Re: Compression Test 1976 305
I know very little about compression, but the #'s look OK to me. Looks like even wear on all cylinders. IIRC, ideal is 150 PSI with 10% or less variation between all cylinders, which you have. Your rings are probably showing a little wear.
I can't comment on the cold vs. warm engine testing.
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 01-29-2007, 11:59 PM   #3
wheels67
wheels67's Avatar
Yep , pretty standard for a 76. If its not smoking then you can get a little more time out of her.
wheels67 is offline   Reply With Quote
Old 01-30-2007, 12:07 AM   #4
84_4x4
84_4x4's Avatar
shows your valves and head gaskets are intact not bad readings at all
84_4x4 is offline   Reply With Quote
Old 01-30-2007, 01:34 AM   #5
rick0312
rick0312's Avatar
great!! I'll clean her up and keep her going!!
Old 01-30-2007, 03:54 PM   #6
rick0312
rick0312's Avatar
ttt
