Old 01-30-2007, 08:52 AM   #1
tallhoedude
ROCKWELL 5 TON CLUB !!
tallhoedude's Avatar
orig fuel tank??
this is the fuel tank that i pulled out of my 70k5.it is alum. and fit perfect between the frame rails.filler neck and vent in correct location.is this a factory tank?
if i decide not to use it,anyone interested?whats it worth?thanks
1970 K5 "ON THE ROCKS" PROJECT:500hp 6.0 fuel injected. 2wd sm465 trans,t136 2.5 ton transfercase,5ton rockwells with 9.34 gears,custom wheel disc brakes,full hydro steering20+" OF LIFT AND 67/35/25's..67" tall TRACTOR TIRES.."THE MUD SLUT!!"
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=221935
1997 TAHOE,SAS D60 14B,5:13 DISC BRAKES,CROSSOVER STEER,HYDRO ASSIST,42 IROKS
HINT:NEW NAME "K5ontheROCKS!"
tallhoedude is offline   Reply With Quote
Old 01-30-2007, 09:27 AM   #2
Huck
Huck's Avatar
Re: orig fuel tank??
NO. The factory tank has rounded corners and has a seam in the middle. this is an aftermarket tank either home made or ?? Nothing wrong with that ---so I would use it in a second as it is probably stronger then stock and if aluminum, lighter too!!
Huck is offline   Reply With Quote
Old 01-30-2007, 10:07 AM   #3
Burt4x4
Burt4x4's Avatar
I agree with Huck
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 01-30-2007, 11:12 AM   #4
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Definatly not stock. I Wonder if it holds more gas though. Looks to be in good shape.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 01-30-2007, 11:42 AM   #5
Critter
Future TOTM Winner
Critter's Avatar
Yeah, do you know how many gallons it holds? Looks to be pretty well built.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 01-30-2007, 12:12 PM   #6
tallhoedude
I Havent Driven The Truck A Whole Lot,basically Just Back From Florida.i Would Run The Gauge Down To E And Refill @ Around 18gals.im Not Sure What The Stock Capacity Is.the Tank Is Really Nicely Built And Solid,has A Baffle Inside Plus Like I Said The Vents And Fillers Are Perfect Fit For The K5.im Going With A Fi Setup On My Blaz.this Might Be An Easy Tank To Modify For Vents/returns Etc.well See.
MY BUILD THREAD:
Old 01-30-2007, 12:51 PM   #7
65-72 chevytoys
65-72 chevytoys's Avatar
I would take it and have it pressure tested.
2004 Chevy Silverado 1500LS SWB 5.3L
2004 Corvette Z16 #770
Wish I had not sold 72 blazer
65-72 chevytoys is offline   Reply With Quote
Old 01-30-2007, 01:09 PM   #8
vtblazer
vtblazer's Avatar
USE IT!
Thats a nice tank.
Go to tanksinc.com
They have in-tank pump tank kits, should fill the bill perfectly.
Here's the link.
http://www.tanksinc.com/cartimages/page_lg_24.jpg
vtblazer is offline   Reply With Quote
Old 02-03-2007, 09:19 AM   #9
bigdon-70blazer
Here is a stock one for the 70 K-5
bigdon-70blazer is offline   Reply With Quote
Old 02-03-2007, 12:44 PM   #10
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
No, like others have said, but very nice, use it
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
