01-30-2007, 04:00 PM | #1 |
I "thought" I had good throttle response.
01-30-2007, 04:24 PM | #2 |
72 chevy
Re: I "thought" I had good throttle response.
WOW that is cool!
01-30-2007, 04:29 PM | #3 |
Its always something!
Cool
79 p10 stepvan 72 Short Fleetside 72 Suburban 67 GMC One Ton Flatbed 64 Short Fleetside 57 Chevy 2DR Hard Top 57 Chevy 2dr wagon 65 f*** short fleet 63 C 60 Flatbed Member of the patina club |
01-30-2007, 04:34 PM | #4 |
I want one.
01-30-2007, 05:12 PM | #5 |
Texas Big Wig
That ain't no kitty, it's monster... Did you here it bark
I'm stealing one and putting it in my Volkswagen |
01-30-2007, 05:15 PM | #6 |
I just had to watch it again. When it's idling it sounds like a really pissed off dog!
01-30-2007, 05:20 PM | #7 |
thats crazy! quicker throttle response then my bike! holy cow!
2008 Ford FX2 Screw 1971 C10 project in shop now! 2004 Pontiac Grandam (wifes) 2000 Cavalier z24 (gas saver) |
01-30-2007, 05:42 PM | #8 |
Texas Big Wig
Just a little trivia
Some of the engines in those cars are so advanced that the team doesn't even own the engine I think it's the Mercedes engine, the team can only lease the engine |
01-30-2007, 05:49 PM | #9 |
rotary engines with no swinging parts like a rod or a piston, turning in excess of 15,000 (yeah that many zeroes!). They have excelleration just like the throttle response. Just think the fastest rod/piston motor turns around 9,000 (Nascar and drag racing) 15,000 is insane, which is why it sounds like a chainsaw on nitro!!
01-30-2007, 06:28 PM | #10 |
That motor is turning 19,000RPM!!!!!!!!
01-30-2007, 06:34 PM | #11 |
Broken Down
Whos got the marshmellows its smores time cook it on the exhaust.....
kenm78 1982 Chevy 4X4 Project truck “It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt” |
01-30-2007, 06:59 PM | #12 |
that was pretty cool i would love to see a rotary engine run in person we've got one at school but it don't do nuthin but sit there so kinda hard to see how it works
01-30-2007, 07:03 PM | #13 |
I'm pretty sure that is a V8.
Here is what wikipedia had to say about it: 2006 For 2006, the engines must be 90° V8 of 2.4 litres maximum capacity with a 98 mm maximum circular bore, which imply a 39.7 mm minimum stroke. They have two inlet and two exhaust circular valves per cylinder, are normally-aspirated and must have a 95 kg minimum weight. Previous year's engines with a rev-limiter are permitted for 2006 and 2007 for teams who can't obtain a competitive V8. Pre-cooling air before it enters the cylinders, injection of any substance other than air and fuel into the cylinders, variable-geometry intake and exhaust systems, variable valve timing are forbidden. Each cylinder can have only one fuel injector and a single plug spark ignition. Separate starting devices are used to start engines in the pits and on the grid. The crankcase and cylinder block must be made of cast or wrought aluminium alloys. The crankshaft and camshafts must be made from an iron alloy, pistons from an aluminium alloy and valves from alloys based on iron, nickel, cobalt or titanium. The complete rules are available from the FIA Formula One world championship regulations. [4] This is leading to a power reduction of around 20% from the three litre engines. For example, Toyota F1 announces an approximately 740 hp output at 19000 rpm in its new RVX-06 engine [5], but real figures are of course difficult to obtain. |
01-30-2007, 07:14 PM | #14 |
I might be way off here, but didn't the guy who invented the rotary motor try to get Honda to put it in their cars?
1972 Chevy LWB K10 Custom/Deluxe Earth first! We'll log the other planet's later. |
01-30-2007, 08:01 PM | #15 |
The Engine Whisperer
My dad used to work a dragstrip and there was a guy who had a 68 camaro with a smallblock in it, claimed to have about $35k in it(back in the 80's!), anyways supposedly the biggest tach you could get back then was about 12k, and this motor would bury the needle on it, so there guessing it would turn 14,000rpm, and it ran just fine and didnt miss a beat. He'd sit on the line with his foot to the floor and just dump the clutch when the green light came.
01-30-2007, 08:16 PM | #16 |
I used to know a guy....
I think 9-10k rpm is the limit (Top fuel Dragster: Weight: 2150 lbs. With Driver: Wheel base: 296 inches: Fuel Capacity: ... ENGINE: Type: Keith Black Aluminum hemi: HP@RPM: 5000@8000: Displacement: 498 c.i. Bore/Stroke), but I might be wrong, heck I probably am since F1's don't run rotaries anymore right? Heck just ignore anything I posted its all wrong cause wilpedia says so. Well, I think that motor in the vid is a rotary, they may have changed (Not snotty enough to give two $h!t$ about F1) but the one in this thread is a rotary. Last edited by 70rs/ss; 01-30-2007 at 08:41 PM. |
01-30-2007, 10:18 PM | #17 |
Thats no rotary, and its WAY past 19k...
We have worked very closely with Del West (the guys that make most of the F1 valvetrains) and the current F1 engines turn over 22k. Im told that Honda has a motor they can run on the Spintron to over 27k but current fuel wont burn past about 24k. BTW, no valve springs, all air baby, and the greatest gains they have made in the last 5 years have been from the reduction in friction... One place that limited rotary technology besides the wipers. We spin our supersport motors to 18k (600cc and about 125hp) Superbike motors are 15k (240+hp and 1000cc's) Our motors are FAR more square than a F1 motor.. think that the v10 engine is only 2.4 liters, and has a SUPER short stroke... we have 4 cyl and 1000cc But you couldnt even imagine the cost, even to build a superbike motor... Rods are $1500ea, pistons are $1k a set, without rings or pins, Crank is 5K, radiator is $8k... But the real expense is in the electronics... Our Motech traction control system is about $45k, but also has 128 channels of data, although we cant use telemetry during racing, only testing.
1970 C10, shortened long bed, Alum Headed full roller 383 (with Victor, 750DP, stainless rockers, behive springs, CNC ported heads) TCI SSF 700R4, 4.10 Posi, Bagged on C-Notch and 2.5 spindles. Air Cond, black out tint, satin black paint, custom interior, rolling low and not so slow... |
01-30-2007, 11:26 PM | #18 |
I'm watching you!
2012 Chevrolet Silverado 1500 Z71 4WD 1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP) 1992 Chevrolet S10 - LS swap project 1968 Chevrolet C-10 longbed fleetside - sold |
01-31-2007, 10:44 AM | #19 |
Licensed to Thrill!
This is throttle response.
http://www.youtube.com/watch?v=XR7aF4hY9rU (Watch the last half of the video). Nothing goes 0-60, 0-100, 0-200, 0-330+ faster on land. Top Fuel Dragsters are amazing. I must concur though - the RPM's at which Forumla 1 turns is amazing. It is so much more amazing than Nascar in my mind in terms of engineering. People talk about how advanced a Nascar engine is - it is not much compared to those. |
01-31-2007, 11:37 AM | #20 | |
Geez. |
01-31-2007, 12:44 PM | #21 | |
In Memoriam...
NASCAR engines are forced to meet a very strict engine formula, and while they may not have the latest tech advances incorportated, I'd rather not say that they are not as highly engineered as any other race motors. F1 and Top Fuel engines are amazing, but let's see 'em run 200 mph for 500-600 miles at Talledega or Atlanta...
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." Last edited by FarmTruk; 01-31-2007 at 01:01 PM. |
01-31-2007, 01:05 PM | #22 |
I am not sure either, that's why I posted what I did. If these are piston rod motors, then technology has gone a long way. That being said motorcycles I would not consider a rod piston in the same catagory as a V8 (but they are rod and piston) and a street bike can turn 12,000 ish RPMs so if you run a short rod and light parts it can happen. BUT Nascar and Drag racing use traditional V8 architecture and only turn in the 8,000 rpm range for a dragster and 9,000 range for NASCAR (but as posted above, that is 9,000 for 5-600 miles at almost 200mph!! not getting on anybody, just stating my absence from paying attention to the F1, Indy and IRL cars, cause at one point it was rotary, but not now.
01-31-2007, 01:21 PM | #23 | ||
motosavvy.com on the "06 R6 All piston engines. To the best of my knowledge, (which regarding F1 ain't all that great) F1 has never used rotary engines. there was a FM (Formula Mazda class though) List of Formula 1 engines 1941 to present Formula Mazda
Oscar '72 Shortbed Fleetside '95 Jimmy 4X4 '69 GMC Custom Camper Last edited by FLEET72; 01-31-2007 at 04:29 PM. Reason: added supporting data |
01-31-2007, 06:47 PM | #24 |
there mostly V10 engines now naturally aspirated , they run everything from 4 cylinders to 12 cylinder boxerengines all sorts of turbo's compressors gearboxes if these engines break right after they cross the finisch the engineers done a good job if they run 2 more laps the engineers made it too heavy
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
01-31-2007, 09:37 PM | #25 |
[QUOTE=FLEET72;2010638]Modern production sportbikes all have redlines well over 9k. My '01 1200 Bandit (which is classified as a standard) reds at 11,000. The 06 Yamaha R6; quoting Barry Winfield @ motosavvy.comThe R6 weighs in around 420lbs
All piston engines. I guess since we were talking about car engines I thought everyone would assume we were talking about cars, but I later mentioned v8, Nascar, and drag racing and threw in the part about bikes (aknowledging stock CBR's and the like spin to 12k rpm). A V8, V10 (not F1) maxes at about 9k rpm. If you can find me a conventional V8, v10, v12 (again not F1) that spins over 9K rpm then I'll be impressed. From what I got from the F1 stuff is that they are super small displacements (smaller parts means lighter) like V10-12's with 3.0 liters. Are they like 12 cylinder weed wackers? My weed wacker spins like 15-20,000 rpm X's 12 still wouldn't be impressive in a car. All joking aside, a V10 that dispaces 2 or 3 litres, the pistons must be pretty small and then that makes sense. |
