Need some measurements
Hello,
I just joined here and I like what I see. I work on an oil tanker and would like to make some shackle brackets to lift one of my K-20s. Rather than have my wife or 14 year old daughter lay in the snow, could someone please measure the rear shackle bracket rivet placement for me? Thanks:
1967 K-20, 1969 K-20, 1970 C-30 dump,1971 K-20 1972 K-20, 1972 C-10, 1968 Grandprix John Deere 350c Dozer, 3414 International backhoe 1972 International 1600 Flatbed |
Re: Need some measurements
Welcome to the board from West Michigan!
If I knew what you wanted I could go lay in the snow and get a measurement for you. Will you please elaborate on what you need for a measurement as there are several rivets holding the bracket to the frame. (Or do you mean all of them?) Jim |
Jim,
Thanks for the reply!!! I need all 6 of them. I there are 4 on the face of the frame, and 2 on the bottom. I wish I could draw a picture to make it easier. It would be best if you could reference them from the bottom of the frame channel. Close is good enough since the rivetsare 3/8 and I will be using 1/2" bolts to install my brackets Dan
![]() Join Date: Oct 2006
Are you doing a shackle flip or droping the bracket lowwer?
I am doing a shakle flip and enough extra to get a 6"lift. I already have front springs and am to cheap to by these. http://www.offroaddesign.com./catalog/shacklekit.htm
