Gone Fishing
Will a 700r4 from a 84 s-10 blazer work in our trucks
Will a 700r4 from a 84 s-10 blazer work in my 68? It had a 2.8 in front of it originally. I will get it rebuilt before I ever use it. Just wanted to know if it would work
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
Re: Will a 700r4 from a 84 s-10 blazer work in our trucks
You will need an automatic crossmember which is no big deal.
Are you sure that a 700r4 came in a s-10? Just looking at one they appear too large for a s-10 truck or blazer. I know some on the board say to stay away from certain years of this tranny as they are weak and not quite as good as some later year 700's. I am not sure which years are the best.
ongoing 1970 c 10 lwb ![]() 1994 z-28 few mods.-owned since new ![]() 1978 vette silver/grey 25th anniv. paint ![]() |
Yes Chevybill 700r4 came factory in the 4.3 S10's . If it was behind a 2.8. then no it won't work because a 2.8 had a different bell housing bolt pattern. now if it was a 4.3 S10. then the bell housing well bolt to a small block.
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
I had an 84 s-15 GMC with the 2.8 and the trans will not bolt up to a SBC the only engines with the same bolt pattern are the 4.3 v-6s. The trans is not called a 700r4 IIRC. I would have to look up the manual to see what it was called. Now it may be that the blazer is different so don't take this as gospel.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Gone Fishing
Thanks guys i found the info already
2.8 and 4.3 S 10 came with 700. Yes the bellhousing is different on the 2.8. The 4.3 700 is different from V 8 version on the inside ( less clutches on a 4.3 unit ) these are still ok if you dont pull hard or put lots of power to it.
and the 4.3 700r4 case is diffent too they dont have the small ears on the front where it monts the to motor but its wont effect anything, may be better to clear headers tho
