Old 01-31-2007, 03:26 AM   #1
Paso76GMCstepper
Paso76GMCstepper's Avatar
Steering Column Question
I scored a complete steering column from a buddy for my 76 K5 for 25 bucks today.
It has all the wiring and the fuseblock attached.
My column wires were cute above the column plug by the previous owner.
My question is the column has a whole in the plastic cover right below the ignition switch. Can I put the one off my column (its not broken) onto the new column I have. Other than that small whole everything is there and in perfec t shape. The fuse block and everything will be spliced in the right way. God knows why the previous owner cut the wires but he did. I have them spliced together but its an absolute mess under my dash. With this new column and all the wireing intact it should be as easy as bolt it in and solice her in.
Right???
Tony
"Life is a Team Sport"
To the memory of the Hendrick Motorsports Plane Crash Victims
Paso76GMCstepper is offline   Reply With Quote
Old 01-31-2007, 12:52 PM   #2
wedgemon
wedgemon's Avatar
Re: Steering Column Question
Paso:
Best route may be to find an appropriate 76 junker with good column wiring. Once the lock plate is removed from these things the column wiring (once umplugged below) slides right out the top. Then you just slide down your good column and plug it in. No more splices!!
- Dave
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
