01-31-2007, 11:08 AM | #1 |
New around here,sorta
Hi guys I'm kinda new here..I was on here a few years back,when I had a 72 chevy c10..That truck is gone and I've bought and started a new project..Now my extra money is going into a 50 chevy 1/2 ton swb street rod project,that I've had a love/hate relationship with for about 3 years.I have had it subframed with a 79 camaro stub,it has a disc brake posi rear out of a mid 80's t/a,and i am going to run a goodwrench 350 4 bolt main/700r4(rebuilt with corvette servo,shift kit,and rewired lock up)..Tilt column with no key switch out of a chevy van..power brake booster/master cyl.,out of same 4wdb t/a. I got a heck of a deal on new bedsides/front bed panel/and running boards,so that will save me time on that ..Right now I am focussing on rust repair on the cab,that i thought was in decent shape,boy was i wrong!!!I am in the process of installing new front floor pans,inner/outer cowl panels,and floor supports..Then i will replace the cab corners..That should keep me scratching my head for a while, then I can get on to the good stuff..I will try to post some pics of the truck..Thanks,I look forward to reading the new posts,and checking out all of your current projects..
50 chevy street rod in progress,or regress depending on the day,(mostly regress!!!) |
01-31-2007, 11:49 AM | #2 |
Re: New around here,sorta
Welcome back and post lots of pictures. I am doing the floors, inner cowl and 1 outer cowl panel on my dads truck right now. Good luck
Bernie |
01-31-2007, 03:01 PM | #3 |
Welcome back!
Sounds like you've got a good start. I'm still trying to sort out the running gear on mine.
51 3100 build thread http://67-72chevytrucks.com/vboard/s...light=stevehsd 77 FLH |
01-31-2007, 05:00 PM | #4 |
Welcome back to the board from central Califorina!
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
01-31-2007, 06:18 PM | #5 |
Welcome back!! Looks like you have your work 'cut out' for you!!!
02-04-2007, 07:19 PM | #6 |
Good Luck and welcome back!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe |
