![]() Join Date: Aug 2003
Valve Covers and Dress-up Kits??
Guys, I’m running a 1977 Corvette 350 in my ‘68 and its very stock and I would like to add more Chrome. I was wondering about which type of Valve covers to get and which would hold up the best. I don’t want to put all this time and money into it and then have them leak.
I’ve seen the Dress-up kits in Summit, but was wondering about the Covers and whether or not those covers would be a good choice? Also, what about aluminum? Does anyone make these and if so, are they big bucks? The covers have the PCV Valve on the driver’s side and the oil fill is on the Passenger side, along with another “valve” of some kind that’s supposed to connect to the Air Filter. I can’t remember what this is or called. Will it be okay to use the Chrome “Breathers” in these holes for Crankcase ventilation? Any recommendations and/or links will be greatly appreciated.
1968 SWB. GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators. Remember, no matter where you go, There you are. Gary |
Active Member
Re: Valve Covers and Dress-up Kits??
Go with cast AL if you want a long rust free life.
If you live someplace the engine gets wet (daily driver) the chrome plated units will only last a coule of years. Edelbrock makes sharp matching air cleaners and valve covers.
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
Sinister Exaggerator
I got a set of polished cast aluminum from summit for around 50 and I really like them. don't waste your time with cheap chrome, you will only hate yourself for it. but if you do just get the spreader tabs and do not over tighten them.
69 c10 Chevy Long Fleet 350/350 *under construction* Poor man's disc brake upgrade with HydroBoost from '82 diesel Blazer tank with "John Fabris" stake pocket filler (Genius!) |
Parts and more parts
I put the Chevrolet Performance Chrome/aluminum valve covers on my Son's truck. They look great, have a nice finish that will not rust and I have had no leaks from them.
The cast aluminum also dissipates heat better than chrome.
The Fastor Pastor '68 swb, 447 BBC/ 6-71 Weiand, Dual 950 Bigs Carbs/ 2 1/2" Header tubes - 4" collectors/ M-21 4speed: '70 swb; TH-400 - bagged & shaved. Looking for new engine or parts. Wife - Original {A Real Classic!} ![]() |
go for aluminium, chrome holds in heat
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
I've got a set of tall Edelbrock Elite valve covers and they don't leak. Got the matching cleaner and it looks great!
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland www.YouTube.com/user/593Films - Watch My Videos! ![]() 1977 Silverado K10 2014 Dodge Durango (Wife-mobile) 2008 Dodge Ram Lone Star Edition (Daily driver) |
billet!!
69 4wd V6 20k orig miles!! ![]() 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. ![]() 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
![]() Join Date: Jul 2003
1lowdiesel-
Where did the air cleaner housing come from? Thanks
1968 Chevy C10 Short Fleetside/Wood floor ECE 4-6 Drop / 406 Small Block 1971 Chevelle 427 Big Block |
Thanks for all the advise.
What about the Breathers?? I want to keep an Oil fill on one of them, but not sure about if I should have a breather for both sides? Any advise?
First of all, you really do NOT want a breather cap on both valve covers. The design is to take air in one side of the motor and sweep it through the crankcase to purge oil vapors out through the PCV valve on the other side. If you put a breathe rcap on both valve covers, you will short circuit your air flow and gasses in the crankcase will build up. A lot of the dress up kits, combine the oil fill and a breather cap ALL into one. With today's designs and styles, the thought is to keep one side as the PCV valve with a line to the front of the carb base and the other is a breather of some sort. My breathers are connected to the air cleaner to keep any oil fumes from creating a mess on the valve covers. However, there are just straight breathers that are open to the atmosphere and allows the fumes to escape.
If you chose the chrome "Metal" valve cover design, then the breather caps and the PCV is easy, cheap, and simple. If you go with the aluminum valve covers and you want breathers and PCV to match them, then the price does go up. For my 383, I put two (2) "Billet Specialties" PCV combination caps on my aluminum valve covers. I took the PCV valve out of one of them, so that the air could flow in a path from the air cleaner to the block. Now the caps are matched on both sides. When I need to fill with oil, I pour it down through the hole that the cap fits into. Last edited by piecesparts; 02-02-2007 at 09:12 PM. |
hey 1lowdiesel.....what pully setup is that from? and how much was it? don't mean to hijack your thread 96blzr
67 small windowed,shortbed,fleetside, sbc 327, th350,12 bolt :under the knife: 71 cab for sale in parts classifieds! 2004 black chevy 1500 "finish your beer, theres sober kids in india!" ![]() |
#13 |
Sierra Grande Club
It’s been my experience that chrome leaks. So if you don’t want leaks stay away from chrome. Polished aluminum is ok though.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
#14 |
Anything that is cast or billet will seal better than stamped steel in my opinion. With valve covers, you get what you pay for, so I'd go with the better ones.
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
#15 | |
I would like to comment here. It is not that Chrome leaks and aluminum does not; it is that "CHEAP METAL REPOP ITEMS" from a chinese/taiwanese factory, leaks (they just happened to be chromed so the public will buy them). Our manufacturing outlets around here want to build a business of dressing up the engines, but cheap guys like us want the prices where we can afford them. That leaves us with an overseas made quality that just plain sux. I disagree that chrome leaks, because I have been running chrome things for years and most of it was done on my own. I took my items to a chroming facility and had it done. I did do the cheap stuff a couple of times and was able to get them to seal, but it took time. Did you know that 90% of the dress up parts that you buy from the GM Perfromance parts group are just that, a foreign made quality. Those parts are purchsed through a company called "PROFORM" and they arrive at your house with a small sticker inside them that say made in China (even the aluminum ones). That is why I said, that I delved into the world of the cheaper parts and made them work. If you open a Summit or Jegs catalog and look at aluminum or chrome valve covers, that are priced competively, then in most cases they ARE just that. IF you can't screw it up looking pretty, then you ain't doing it right. |
#16 |
New Member
Its been my experience, that what leaks is by far NOT the valve covers you use, but the Valve Cover Gasket. I personally don't use the POS cork gaskets, I always use the rubber ones with the thin piece of steel in the middle. They are pricey, but never leak. I have never had an issue with a Valve Cover itself leaking. Buy the Valve Covers that you like the best, and then get the good gaskets. You can reuse the rubber ones, and you don't have to put all that gunky silicone all over your stuff. Be sure and get the correct grommets for the PCV and Breather. Just my .02 cents
#17 |
i'm gonna start a thread on the motor and car. so i don't hijack any threads.
#18 |
If you buy aluminum and are lazy like me, after awhile they dull. You have to pull them off and polish them. Not hard to do just time consuming. My two cents. Kerry
1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT |
#19 | |
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) ![]() 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again ![]() 2002 Tarus (my wife loves that car) |
#20 | |
And thanks to everyone else for their input too. Looks like I still have a little research to do, but I'm getting a beeter grip on all this. piecesparts. Thanks for explaining the "breather" aspect.
