Old 01-31-2007, 10:17 PM   #1
bad72c10
bad72c10's Avatar
Seat and Transmission Questions
Okay first question is, can someone snap a picture of the passenger side seat track, particularly the reatiner. Mine doesn't work, well, it does until weight is put on it, and then it unlocks and can slide forward.
Second, is about a B&M shift improver kit for my TH350. Is it worth it? Does it stiffen up the 1-2 shift or what? Do you have to pull the tranny or just the pan? Just wondering. My tranny shifts really smoothly right now, but it might be good to shorten and stiffen it a little. Also, did you put the stage one (RV/towing), or stage two (street/strip) in? Thanks guys, Justin
'72 C/10 SWB 355/ broken TH350 and 3.07s Soon to be 355/700r4 and 3.73s
bad72c10 is offline   Reply With Quote
Old 01-31-2007, 10:45 PM   #2
WorkinLonghorn
WorkinLonghorn's Avatar
Re: Seat and Transmission Questions
I've never used that particular kit but when I used to work at a trans shop we used to put in shift kits all the time to firm up the shifts.You just drop the pan and work on the valve body.It's REAL easy.I remember on some you had to drill out a passage with the bit they provided,and some other real easy stuff.I'll let others who have used those particular kits describe their qualities,but if I had to guess,I'd say the first level would be fine unless you like a jolt on every shift at any speed,but I'm guessing here.-Brian
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 02-01-2007, 02:13 PM   #3
bad72c10
bad72c10's Avatar
Thanks workinlonghorn, anyone else?? Justin
Old 02-01-2007, 02:37 PM   #4
speedracer
Blank
speedracer's Avatar
the kit is worth every penny... as far as the setting, that depends on what your doing with your truck. I had a th350 with the street strip and it would chirp second if I wanted it to.
1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi.
1977 Corvette 350-375hp 4speed, silver show car.
2002 S10 xtreme, work truck
2004.5 VW jetta GLI 1.8T 6speed, weekend warrior.
2013 Audi A3 TDI, the wife's car
speedracer is offline   Reply With Quote
Old 02-01-2007, 11:58 PM   #5
bad72c10
bad72c10's Avatar
Well, it'll be a fun street truck. I think chirpin them would be pretty cool, but I also don't want to hit my head on the steering wheel from the jerk of the shift. I don't know how hard it shifts exactly. Thanks guys, anyone else??
Old 02-02-2007, 12:57 AM   #6
skchevota
skchevota's Avatar
Ive used he b&M kit before, it was nice, shifted smooth if I was just cruzen in drive, shifted harder if I got on it, and if I shifted it manualy it would bark 2nd real good. I used the street and strip mode. the race mode is toooooooo harsh for daily driving unless you like to rattle your fillings out.
skchevota is offline   Reply With Quote
