window question???
how do you take a window out of one door and put it in another???
thanks
67 chevy c 10 2x4 350/700r4 short/fleet 90 Chevy 1500 4x4 350/5 spd short/fleet 90 Chevy 454 ss 93 chevy camaro z28 auto t-tops 2013 Chevy Silverado LT CCSB 4x4 |
Re: window question???
Either take the glass track off the regulator, or take the glass out of the glass track.
but how do you take the glass out of the glass track, is there some trick to taking it out or should it just pop out and pop back in???
I usually unbolt the regulator, then remove the rollers out the end of the groove on the window, then lift the window out.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
They are pressed in.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
Heres how to change the regulator in the FAQ, you have to take the window out to do this so
http://www.67-72chevytrucks.com/vboa...d.php?t=157539
'65 Chevy 1/2 ton Longbed ![]() ![]() |
