Old 08-26-2002, 07:17 PM   #1
sam's 72
Question Help me out with painting my grill!
I pulled the grill out of my 72 chevy, ( egg crate looking grill ) I want to paint it black. What type paint is best to use? ( I will be useing spray paint cans ) And what is the best way to prep it? Also do I need primer? If so what type? I do not have a paint sprayer. Will be useing cans, semi gloss black for final color.
So what do you guy recomend? I have seen some painted before with the paint peeling off. I am trying to avoid this.
Sam
72 LWB chevy truck.
Pasadena, Texas
sam's 72 is offline   Reply With Quote
Old 08-26-2002, 07:54 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
i just hosed mine with rattle cans, flat black faded a bit but no peeling...
if you're concerned give it a couple coats of primer first...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 08-26-2002, 07:57 PM   #3
Wabash
Wabash's Avatar
i just did this and i used a brand of paint called PLASTI-KOTE
it turned out fairly well.
i first used primer then the gloss black and then i also used some clear cote
i think it turned out fairly well.
i also put on several cotes of each and hopefully this will avoid the peeling.
i will post a pic when i get a chance
1972 C/10 LWB
1972 K/5 Blazer
Wabash is offline   Reply With Quote
Old 08-27-2002, 08:16 AM   #4
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
After the grill is cleaned (soap and water) and just prior to painting, clean with carb or brake cleaner to remove any lasting wax or grease. I would lightly prime and then spray with Krylon's semi flat black. You should have no peeling problems.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 08-28-2002, 05:45 PM   #5
primerib
Any suggestions for painting an egg-crate grill to make it look like a new one? Mine is all in one piece, but it's very faded.
primerib is offline   Reply With Quote
Old 08-29-2002, 08:36 AM   #6
bobs409
bobs409's Avatar
I would spray it with an argent silver color which is semi flat and I believe used on rally wheels. If you can find the correct shade of silver, it should look like new when done.
Bob
