engine parts needed
hey guys, trying to get this 400 sb finished and need a few things. thought i would ask before calling summit, see if anyone has some extra stuff collecting dust.
complete oil set up-pan,pick up, pump. the whole nine yards. want something around 7 quarts, also windage tray. fuel lines from mech. pump to dual feed holly stewart water pump "short" new arp head bolts cloyes double timing chain harmonic balancer install tool manifold engine lift plate HEI good for 6000 rpm quality set of universal 90 degree boot 8mm plug wires prefer black complete external engine bolt set from pan to intake so if anyone has some extra stuff laying around shoot me a pm thanks. pkj |
Re: engine parts needed
shoot me an email at cst70rocket@yahoo.com
I have an Moroso oil pan/pickup/reusable fel-pro 1 pc gasket. This is for 2 pc rear seal engine, drivers side dipstick, 7 qt. no kick out 8.25" deep sump. Pan was used for 8 passes on a 383 before the mains went. Seems 12 psi of boost will take a stock 400 crank with the mains turned down and make it go limp! Pan is perfect, and the pickup is clean. No oil pump though. $100 takes it. Kirk http://img.photobucket.com/albums/v6...1/lowpan-1.jpg ![]() |
I have an Moroso oil pan/pickup/reusable fel-pro 1 pc gasket. This is for 2 pc rear seal engine, drivers side dipstick, 7 qt. no kick out 8.25" deep sump. Pan was used for 8 passes on a 383 before the mains went. Seems 12 psi of boost will take a stock 400 crank with the mains turned down and make it go limp! Pan is perfect, and the pickup is clean. No oil pump though. $100 takes it. Kirk ![]() ![]() |
I have an Moroso oil pan/pickup/reusable fel-pro 1 pc gasket. This is for 2 pc rear seal engine, drivers side dipstick, 7 qt. no kick out 8.25" deep sump. Pan was used for 8 passes on a 383 before the mains went. Seems 12 psi of boost will take a stock 400 crank with the mains turned down and make it go limp! Pan is perfect, and the pickup is clean. No oil pump though. $100 takes it. Kirk ![]() ![]() That is a stain in the bottom of the pan, and it will be thoroughly cleaned before shipping. |
hey cst70rocket, i sent you a e-mail. thanks
Did ya buy cst70's pan? Still lookin?
I've got a 7 qt pan I'll sell.
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
pm sent
