Old 08-26-2002, 07:40 PM   #1
Durney
Found it !
Just a note to all the guys that have helped in the last few weeks in my search for a 67-68 3/4 ton 4X4....thank you for all the e-mails and even the local traders (Mike)!
Its a MINT 67 C20 Chevrolet..... that has already had a frame off resto done in 2000. (so much for me having the fun). But I am still going to think about a new powerplant and switch to an overdrive unit (its got the manual 4-sp in it now).
What were the standard trans options and differential ratios?
thanks again folks...
Durney is offline   Reply With Quote
Old 08-26-2002, 09:30 PM   #2
Fast68Chevy
Fast68Chevy's Avatar
67 C20, std tranny was Sm326 and 4.57 ratio rear axle
available was 4.10, and 4 speed granny toploader tranny(SM420)
good luck and congrats
Fast68Chevy is offline   Reply With Quote
Old 08-26-2002, 10:46 PM   #3
ThreeQuarter
ThreeQuarter's Avatar
You GOTTA show pics now. It's an obligation you have to fill since we helped in your search.
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'16 GMC Sierra 1500 SLE Dblcab 4wd 5.3
ThreeQuarter is offline   Reply With Quote
Old 08-26-2002, 10:50 PM   #4
lukecp
Formerly yellow72custom
lukecp's Avatar
If it is a granny-low 4-spd, it should be a SM420. If you want to keep the 4spd, you could put a Gear Vendors OD behind it. They are indestructable, and will make up for the 4.10 gears you proably have on the highway.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 08-26-2002, 11:30 PM   #5
Durney
Whats the easiest way to ID the two transmissions?
( I assume they are both 4-speeds? )
Is one stronger or easier to find parts for?
I am rethinking the need for a 4L60E as I prefer manuals.
As far as the ratios, I am thinking about just replacing the ring & pinions in the diff's for a more realistic vehicle.
But the GV stuff is nice (if it'll fit between the transfer and carrier bearing)
What were the trim options by the way? (it supposedly has factory AIR but I didnt think that was until 69?)
Old 08-27-2002, 12:03 AM   #6
ThreeQuarter
You could get factory air in '67. Check the options list on the glovebox door for the factory eqipment.
Also check out my '67 C20 on the link in my sig--sounds alot like yours, except for the resto.
Ben
Ben
Old 08-27-2002, 01:09 AM   #7
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Sounds great...let's see those pics!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 08-27-2002, 07:39 AM   #8
Blazer1970
Blazer1970's Avatar
The SM326 is a column shifted 3 speed. The granny low 4 speed is the SM420. The 420 is a good strong tranny, some parts are discontinued, but there are a zillion used trannies out there if you need any gears or anything. You probably have an Eaton rear axle, and I think the highest gear ratio available is 3.90.
Blazer1970 is offline   Reply With Quote
