Old 02-01-2007, 11:02 PM   #1
bbchevy
87 Wanna Be K30
bbchevy's Avatar
Truck shaking horribly
I just swapped in a D60 in the place of my old 44 front axle. Ever since the swap, my truck will shake out of control when i hit a bump. its so bad that it feels like the axle wants to rip out. I have replaced the whole tie rod, drag link, king pins stuff, wheel bearings, calipers and rotors, etc. if i put another stabilizer on it, the shake will die down alot... but it wont go away. what could it possibly be. i never had this problem with the other front axle. And i have the same wheel and tire combination as i did before. I am so confused.... and im getting very frustrated. I need help. thanks guys
-Scott
Was: 1987 V10 Silverado
TBI 350/700R4/208 with 3.42 gears
Is: A wanna be K30
330hp 350/465/205/D60/14FF with 3.73
hydroboost, 4 Core radiator, electric fans, Centerforce Duel Friction, Locker, 6inch Soft ride lift, etc....
bbchevy is offline   Reply With Quote
Old 02-01-2007, 11:26 PM   #2
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: Truck shaking horribly
Double check the axle ubolt torque. It should be around 100 lbs.
DirtyLarry is offline   Reply With Quote
Old 02-01-2007, 11:59 PM   #3
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
and check your castor angle, you may need to shim your axle forward to raise the pinion and level the castor.
also check that your king pin springs are still good, mine had settled about a .25" and wernt putting enough preasure on the king pin, add a thick washer to the spring to stiffen it back up.
did your tires go back on the say way they came off, swapmers are nitorious for getting out of balance and wear patterns will fawk every thing off if they are reversed.
trkklr77 is offline   Reply With Quote
Old 02-02-2007, 01:13 AM   #4
Russell
Professional Grade
Russell's Avatar
maybe take a run over to www.coloradok5.com/forums sign up, and search for "death wobble" All the causes, and fixes have been gone over a number of times there.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 02-03-2007, 10:26 AM   #5
Duro5341
Duro5341's Avatar
Are you sure you shocks in the front are still good
Sound to me that when it hits a bump, the shock can't suppress the axle movement fast enough.....thus causing it to shake, and want to walk on you
Just my 2 cents
Duro
Duro5341 is offline   Reply With Quote
Old 02-04-2007, 01:54 AM   #6
bbchevy
87 Wanna Be K30
bbchevy's Avatar
Ok, the king pin springs are brand new. i replaced all the king pin parts. um... the caster angle is what the mechanic at my work told me but would that really make it shake horribly like that? i heard that the caster only makes the wheel not turn back correctly. And my shocks are brand new pro comp 9000's. so yea. but im def going to check out coloradok5. thanks guys. but while im still here... do you have anymore suggestions now that i gave you more info? thanks again.
-Scott
Is: A wanna be K30
Old 02-04-2007, 02:44 AM   #7
Russell
Professional Grade
Russell's Avatar
There are some washers that sometimes need to be put under the king pins or something that is a pretty common issue...
Again, look up Death Wobble on CK5, and you'll be good to go
Old 02-04-2007, 02:53 AM   #8
bbchevy
87 Wanna Be K30
bbchevy's Avatar
I just made an account at k5 but i cant use the search function. do you think you might be able to send me a link or two from there... that would be awesome. because i cant find the forum. thanks
-Scott
Is: A wanna be K30
Old 02-04-2007, 09:24 AM   #9
rcbildr
rcbildr's Avatar
Castor angle also affects how stable the wheels/steering is and how responsive they are at speed. If the king pins are not angled back far enough it acts like the wheels on a shopping cart.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
