02-01-2007, 11:09 PM | #1 |
Yellow truck club
Question for the guys with a Mustang II front end
Just wondering how you folks raise (jack) up the front of your trucks to get under for service. Do you use the MII cross member to raise it or frame one side at a time?
Thanks ...Brian
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
02-02-2007, 12:32 AM | #2 |
Re: Question for the guys with a Mustang II front end
On my 1948 Chevy 5 window, I have a TCI set up. My tire size if 215-60X15. My floor jack is 4 inches high and just will roll under the TCI cross member. This is where I lift the front end
02-02-2007, 01:17 PM | #3 |
I use the center of the crossmember to jack up the truck, but I have to drive up on a couple of 2X6 to raise the center up high enough to roll the jack under the crossmember!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
