Old 02-01-2007, 11:33 PM   #1
mcmlxix
Collector of Projects
mcmlxix's Avatar
Rear Air Bags and towing? GOOD? BAD? or UGLY?
I was thinking of putting air bag suspension on just the back of my 71 SWB. I eventually want to throw a hitch on there to pull a car trailer... I want some height adjustabilitly in the rear.. Right now I have the ECE 4/6 drop with springs,adjustable panhard bar and shock relocator brackets...
Will bags support a 22ft enclosed trailer with a car?
Is it a problem with bags on the back on springs on the front?
I assume there are different bags rated for different loads?
Does a bigger heavier bag effect ride quality?
Any input would be appreciated...
Rich
1972 K5 Blazer CST Click HERE
Old 02-01-2007, 11:37 PM   #2
krue
Designated A-hole!
krue's Avatar
Re: Rear Air Bags and towing? GOOD? BAD? or UGLY?
I know NOTHING about lowriders or airbags on pickups, but I know my dad's Volve TRUCK uses air bags for suspension, so they have to make some heavy duty bags.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 02-02-2007, 12:19 AM   #3
CMars45000
CMars45000's Avatar
At the shop where I work, we do kelderman and airlift conversions all the time on trucks that people tow A LOT with. many of the systems completely replace the leaf springs in favor of heavy duty bags... the type of the bag and the system would be dependent on the intended application..
Project Family Values Build Thread
Vehicles/Projects:
-1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon...
Pleasure in the job puts perfection in the work.
-Aristotle
CMars45000 is offline   Reply With Quote
Old 02-02-2007, 12:37 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
If you just want to adjust your rear to help handle the load, then buy some small helper bags. The work perfect for hauling loads in a lowered truck.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-02-2007, 06:19 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
bags are for heavy loads, low riders use them for comefort and adjustability.
Old 02-02-2007, 08:21 AM   #6
Rokcrln
Rokcrln's Avatar
Right now I am building a 70(LFD's Low buck truck build) for towing and it is leafg in the rear but will be lowered about 7" out back. I have a set of firestone bags that are going in just for towing and keeping things level. I know you have coils but the added bags would still work the same for when you tow and when you just let out the air and you are back to what you have now. Best of both worlds. Just keep in mind a SWB truck is not ideal for towing that long of a trailer and a coil spring rear adds to the problem because it has a slight side to side shift every time the suspention cycles. Keep it at 55 and you should be fine as long as your load is set right. Mine will be a SWB as well but only towing a 16' Carson steel deck car trailer.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
