lifter's ticking
I did some work on my 68 this weekend. I gave it a tuneup and rebuilt the carb on it. One of several problems I have found is that some of the lifters are stuck. This truck sat for 5-7 years without being started very often. Is there something I can use to free op the lifters so I don't have to tear down the engine right away? I just need to get it running good enough to pass colorado emissions.
67 Grand prix convertable 68 Chevy 3/4 ton truck 66 Cadillac sedan deville |
Ticking lifters
I have never heard of a ticking lifter getting better. Might try some straight 40 weight oil. Also make sure it isn't just a loose rocker/s.
70 Chevy SWB 4x4 350/350/203. 02 Honda VTX. 98 Honda XR400. 88 Honda prelude Si 4WS. 99 Nissan Maxima SE. & one spunky little Jack Russel. |
its all about the +6 inches
If its a lifter, I can't help, but if it is a rocker or a stuck valve, try dumping some tranny fluid down the carb as it is running. The high level of detergent in ATF can break these things loose. (sounds like B.S., but it works.
68cst_ss490
empty your oil out and then add a gallon of diesel fuel and run it for 5-10 minutes keeping an eye on your oil pressure. The oil in the diesel should help it out
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
OzarkHillbilly in Atlanta
flaco ,,,, Mines noisy too
Dean23 ,,,,I had forgot about that trick. My Dad used to do that.
longhornmail ,,, never heard that trick but willing to try it.
72 custom/10 LWB 68 Longhorn C20 Custom Camper (sold) |
now thats a true COON DOG
![]() Join Date: Nov 2000
try some Marval mistery oil in your next oil change! And use it regulary in your gas at fill up, and that should help free them up, and keep things nice and clean inside!
current project 67 ![]() 71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's ( was crushed by a tree, bed sold, motor pulled) ![]() 72 LWB 4x4 350 4-speed 3.08's posi wearing army olive drab green (SOLD!) 68 BURB 50TH LOOKALIKE work in progress, soon to have 250-I6 with a 3-speed on the tree 4.11's and posi ( currently sitting in back yard tarped awaiting time, $$$, and lots of love!) 67 1 TON- work truck 396 sm 420 4-speed, flat bed 4.57 gears "big red" (my first landscape truck, very rusty and crusty! but still gets the job done when needed!) |
