02-02-2007, 12:37 PM | #1 |
anyone put 3/4 ton coil on 1/2 ton?
i need to lift the front of my 2wd 1/2 ton about 2" or so. has anyone tried the 3/4 ton coil?
02-02-2007, 01:30 PM | #2 |
Re: anyone put 3/4 ton coil on 1/2 ton?
of what i remember in my moog spring books , theres a standard 1/2 set , and a heavy 1/2 set( air -bigblock )that was the same part as a stardard 3/4 , plus maybe a 3/4 hd ( air bigblock - 1 ton . a total three diff spring sets for the front , yet they will all interchange
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
02-02-2007, 04:40 PM | #3 |
Yeah, you can put 3/4ton springs on a half ton. I did it on my 67 way back when. It made it ride cinda rough, but it helped the sag from the old worn out ones.
02-02-2007, 08:34 PM | #4 |
yes the HD coils or 1 ton coils will do the trick. I ran them on my 82 c10 and could fit 31s ith no rubbing and 32s with slight rub...
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
02-02-2007, 11:21 PM | #5 |
how much taller would they be? anything about ball joints i gotta worry about?
02-05-2007, 07:21 AM | #6 |
I added 3/4 ton springs to the rear of a 71 swb with a 402 and the 1/2 ton shocks couldn't handle the rebound rates of the new springs so the ride was terrible.
Installed some 3/4 ton shocks and it rode sweet after that. So put the new shocks in while your doing the swap to save the time later. |
08-17-2007, 12:11 PM | #7 |
what about the ball joints?...any problems with them after the new coils?
08-17-2007, 04:37 PM | #8 |
There should be zero issues with the ball joints. If I remember correctly the length of the coils are the same. The heavier duty coils run a larger diameter wire spring, thus changing the rate
08-18-2007, 03:59 AM | #9 |
changing the rate mean no sag thus lifting the front once the truck is sat back down on the ground?
08-18-2007, 07:25 AM | #10 | |
Remember about those shocks... Last edited by vtblazer; 08-18-2007 at 07:25 AM. |
