Old 02-02-2007, 01:33 PM   #1
Hooker
aka TEX-TOY
Hooker's Avatar
Dropping?
What is the lowest i can go in the rear without having to c notch my frame?
I was thinking this 2.5 spindles in the fron with 1 or 2 in springs and 4 or 5 in in the rear with springs... thanks
1969 Chevy C10 SWB w/ disk brakes and soon to be lowered with spindles and springs!!!! Getting a paint job like a Army Chinook Helicopter!!!! HOOKERS RULE!!
BRAND NEW WIFE BOUGHT IT FOR ME AS A WEDDING GIFT!!! SHE IS THE BOMB!!!!!!
Hooker is offline   Reply With Quote
Old 02-02-2007, 01:55 PM   #2
adpostel
New Member
Re: Dropping?
I was wondering the same thing. I need to do the same thing.....
1968 C10 LWB Project 454/400
http://www.cardomain.com/ride/2417713
adpostel is offline   Reply With Quote
Old 02-02-2007, 02:30 PM   #3
COACHMEASON
Keep On Keepin' On
COACHMEASON's Avatar
Re: Dropping?
I have heard 6" in the back is pushing...I am going 5" myself (w/ a panhard bar)
COACHMEASON is offline   Reply With Quote
Old 02-02-2007, 02:36 PM   #4
Hooker
aka TEX-TOY
Hooker's Avatar
Re: Dropping?
did you notch your frame for 5?
Old 02-02-2007, 03:12 PM   #5
Robznob11
Robznob11's Avatar
Re: Dropping?
there was a artical in classic trucks where they put the complete cpp kit on a 65 witch is the same as our coil spring set up and they said you could go 6" with no notches. my truck has 6" drop coils from western chassies got them at sport truck direct, only ones i know of that have 6 any how, there is still alot of room between my frame and axle.however if it ever does hit on a launch it will be a wild ride cause the rears will likley unloade so if that happens i will notch it. i would think you will be ok on a daily driver though
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 02-02-2007, 03:36 PM   #6
powell72
powell72's Avatar
Re: Dropping?
6'' is fine without a notch. There are quite a few of us on here with 6'' drops and no notches. ECE sells 6'' drop coils.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 02-02-2007, 04:37 PM   #7
Ram-Man
Ram-Man's Avatar
Re: Dropping?
From what I read in past posts is you can go 6" without a notch, but I think you will have very little spring travel in the rear.
Ram-Man is offline   Reply With Quote
Old 02-02-2007, 05:35 PM   #8
bigblockorange
Re: Dropping?
I know a local guy who used 4" lift blocks from a lift kit in his 67 shorty he said it worked fine I asked about the pinion angle he said he never lost a U-joint Anyone else try this?
bigblockorange is offline   Reply With Quote
Old 02-02-2007, 05:36 PM   #9
adpostel
New Member
Re: Dropping?
If you do go 6 in the rear with no notch, is the ride really bumpy? Or does that depend on the Shocks you use?
Old 02-02-2007, 11:24 PM   #10
powell72
powell72's Avatar
Re: Dropping?
I use the gray KYB shocks on my truck, the ride is good. The only problem I have is the rear bottoms out on the exhaust once in a while. It's my fault, I routed the exhaust incorrectly for the amount of drop.
Chris
Old 02-03-2007, 12:04 AM   #11
see ten
WTB this ad
see ten's Avatar
Re: Dropping?
I wanted my truck as low as I could get it without having to notch it. The guys at ECE said a 6" drop wouldn't bottom out unless I was loaded. Well as previously stated a lot of guys run 6" of drop out back without problems but sooner or later you are going to bottom out. Yes, 98% of the time while driving unloaded you will be fine but sooner or later you will bottom out. 5" is probably a lot closer to being a worry free drop. I thought about swapping out my rear springs for 5" springs but I really like the way it looks. I wouldn't call the ride harsh, but yes it is more firm than before it was dropped. My truck has 2.5" drop spindles with 1" drop coils up front. Out back are 6" drop coils along with shock relocators and a super track bar. The trailing arm crossmember was swapped for an ECE extreme drop piece.
This is member 71see10's truck. He has stock height front springs along with 2.5" drop spindles up front. Out back he has 5" drop coils along with the super track bar kit.
see ten is offline   Reply With Quote
Old 02-03-2007, 12:39 AM   #12
short69
short69's Avatar
Re: Dropping?
I have 4'' drop springs and 2'' lowering blocks
69 shorty w/ 67 front clip
short69 is offline   Reply With Quote
Old 02-03-2007, 12:41 AM   #13
short69
short69's Avatar
Re: Dropping?
I dont think the photo showed up but it showed that thare is about 4'' of clearance between the axle and the frame
Old 02-03-2007, 01:51 AM   #14
chopper103in
chopper103in's Avatar
Re: Dropping?
i have a 5in drop spring in the back with no problems
69 chevy swb
2.5 in droped spindle with 1 coil cut--5 in dropped spring in rear
5 in dropped spring
307 repaced soon with 350
3sp on tree soon replaced with 350 tubo
06 monte carlo
94 chrysler town & country---198K
84 jag xj6
76 sportster---57 panhead
chopper103in is offline   Reply With Quote
