Gas Cap Fitment
So i just reinstalled the in cab gas tank with new rubber seals and such, and i was wondering how tight the gas cap was supposed to be? The new rubber gromet that goes right beneith the gas cap is a little thick when it overlaps the plastic "locking pipe" for the gas cap. I was wondering if maybe that plastic "pipe" was supposed to come out a little furthur or something? Thanks.....
2000 GMC Sierra EXT Cab Short 4x4, finally mine... 1966 C10 SWB Fleet, 250 I6, three on the tree.... Previously Owned.... 1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4.... 1972 Chevy LWB Fleet 350/350 EXTENDED CAB ALL THE WAY! .._..~...-...._...____ .._..-...______|_|__\____ ..-..~.|_(O)__|_|__|_(O)] |
Re: Gas Cap Fitment
anybody?
Re: Gas Cap Fitment
the in cab tank is vented through the cap so i would say that as long as the caps not loose its fine.
1964 c10 short step 1962 econoline van 1989 rs camaro 2006 yamaha vino 125 1975 goldwing |
Re: Gas Cap Fitment
I encountered the same thing..
I pulled the plastic pipe a little further out.. but it didn't seem to make a difference.. So, I just live with it being a tight fit.. Elias |
Re: Gas Cap Fitment
well i would live with it, except even i cant tighten it down until it locks with one of those jar lid opener things. I think i pull the pipe out a little more and try it out. Thanks guys......
#6 | |
Re: Gas Cap Fitment
Let me know if it works because mine is still a hard to get on and off... Elias |
Re: Gas Cap Fitment
ok no problem.....
Cantankerous Geezer
Re: Gas Cap Fitment
Did you replace the cap, or just the gasket? The newer caps are designed to seal tight and have a spring that will let air get sucked in, but not let vapors out. They also stop gas from spilling down the side. But they shouldn't require a strap wrench to remove. You could always take the gasket to the sander to thin it down a bit.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Re: Gas Cap Fitment
The cap is i think original, it came with the truck when i bought it, but it wasnt installed. I replaced the rubber cuase what the guy gave me was shot. So i just replaced the gasket.....
Cantankerous Geezer
Re: Gas Cap Fitment
A new cap is under $10 at your local parts store. Azone shows them for $6. Has a stainless cover and should screw on properly. Best of all, it won't let gas run down the side of your truck.
Like I said, if you want to, thin down your gasket with a power sander. It's not easy, but it can be done.
Re: Gas Cap Fitment
Thats a goo idea, i think ill go otu and get one of those right now, mines no too shiny anyway. Thanks.....
Brad
Scrapper 1
Re: Gas Cap Fitment
well i hate using the plastic fill pipe if you can the steel matal one is the best one to go with i've had the fiber glass or platic ones and they crack so i found one that was out of a 1960--1966 truck and it worked
#13 |
Re: Gas Cap Fitment
whered u find a steel one? Did u get it form an actual 60 - 66 or did u buy it new? Thanks....
Brad
