Old 02-02-2007, 05:44 PM   #1
timzrides
timzrides's Avatar
1967-1972 cab difference.
Can somebody tell me or assure me that only difference from a 1967 thru 1970 cab and 1971 and 1972 are the vent on the door jams for the gas tank. thanks
timzrides is offline   Reply With Quote
Old 02-02-2007, 07:01 PM   #2
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Re: 1967-1972 cab difference.
I think the gas tank neck hole might be different. 67-68's have different firewall holes than 69-72, and for what its worth, it seems like you are more likely to find rot in the roof or above the windows and doors in a 71-72 cab than the earlier ones, just based on what I've seen. And yes, the 71-72's have those vent thingies. Otherwise, they seem the same.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 02-02-2007, 07:48 PM   #3
lpaine
lpaine's Avatar
The parking brakes are different too, I think 67-68(hand lever) is mounted under the dash, and 69-72 (foot pedal)is mounted on the kick panel.Also, the rear view mirrors are cab-mounted 67-70?, and windsheild mounted (glued) after that.
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 02-02-2007, 08:23 PM   #4
69-350
Oil trash and damn proud of it
69-350's Avatar
71. 72 they were attached to the windshield
Mark
1997 K1500 Z71, 14 bolt SF 3.73 posi, Bright Blue Metallic. 6" Superlift
1972 C-10, toolbox, p/s, 350/TH350/3.73 open, black int., bronze
2008 Dodge MegaCab. H&S tuned 6.7 Cummins. Fast Four Tons
Some of my pics http://s107.photobucket.com/albums/m294/69-350/
69-350 is offline   Reply With Quote
Old 02-02-2007, 09:06 PM   #5
72Chevrolet
72Chevrolet's Avatar
71 was not attached to the windshield, 72 was. There is also some small holes on the door right below the corner windows on a 71 and its not on a 72
72Chevrolet is offline   Reply With Quote
Old 02-02-2007, 10:00 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
71, and only 71, had a raised mounting pad for the mirror, earlier ones, if optioned (was not required till 70) jus drilled holes in the sheet metal
71 started a cable throttle, which had a cowl mounted pedal. The old ones were snapped on 2 'nubs' on the floor, plus, the firewall is not the same between the 2 on this part.
67 and 68 had the hand mounted parking brake handle, which had the cable hole in an odd location compaired to the 69 - 72
67's could be had with small back window... 68 - 72 light duty trucks could not
67/68 had no provisions for door operated dome lamp switches... a raised pad in the forward door jamb.
69 - 72 were offered with a cargo lamp, earlier models could not
69 - 72 were offered with a headliner, which included holes for the trim, earlier models could not (this was only on CST/cheyenne/cheyenne super)
I think there's more, but that's all i can think of at the moment.
Old 02-02-2007, 10:21 PM   #7
Solver
Solver's Avatar
67-68 had a horizontal fuse box while 69-72 had a vertical mounted fuse box.
and the 67 has a smaller ignition bezel hole
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 02-03-2007, 12:56 AM   #8
MT1972cheyenne
MT1972cheyenne's Avatar
The throttle linkages went from rod type to cable type, so the holes in the firewall for throttle linkages are different.
MT1972cheyenne is offline   Reply With Quote
